Any thoughts to the problem would be greatly appreciated.
http://www.batauto.com/cgi-bin/Forum/db_TalkToMeV2.cgi?forum_name=domestics
code 65 is showing (Oldsmobile 1988, 3.8 I, 160K).
the vin is 1G3Cx51C2J1314517
Filling the gas tank did nothing but the next day the engine light would go off. This has happened for the last few tanks of gas.
Any connection between the 2?
Since it hasn't done this before and there is 5 gallons in the tank, then the assumption would have to be that the fuel pickup has moved.
I would take it to the dealer except my son has taken the other car for the summer.
After you check the trouble codes, come back and let us know what you found.
I have a 1986 GMC Suburban (project vehicle). My friend (who was a GM Service Writer once upon a time ) insists that it should have an Assembly Line Data Link. I could never find one on it though, and I don't think that it ever had one. My reasoning for this is based on the fact that it is carbureted (QuadraJet 4barrel, MC series without the adjustable jetting) and it doesn't have a "check engine" or service engine soon light. It is 5.7L, federal/standard emissions.
I also feel it shouldn't have an ALDL since it (apparently) isn't equipped with an ECM. I looked behind the glove box and everywhere else. Besides, it doesn't have an O2 sensor, TPS, IAC or anything else normally considered a part of the TBI or Cal. Emissions system. In fact, it still has the old speedo cable instead of VSS.
What is your take on this?
Thanks in advance.
TxTruckr
I also have questions for you later about troubleshooting high idle problems in a '94 Chevy 3500 CC/Dually 5spd (will post later).
FWIW - I once cleared a "SES" light on my OBDII equipped '96 C1500 (result of loose plug wire after tune-up) by leaving the battery cable off for about an hour, any less and it would still have the code set.
Most trucks were not equipped with fuel injection nor an ECM in 86. Only if the carb is a feedback carb might there be a connector.
The 85 and 86 models are maybe do, maybe don't.
Very few of the 85 models had fuel injection.
No "check engine" light, no ECM, no ADLD connector.
87 was the first year that almost all trucks with the 350 had the ECM.
Have the shop manual and for the LX W/O ABS and following their diagnostic trail, I come up with Intermittent failure, check for poor connections or loose wires at EVAP flow switch and ECM/PCM.
Anyone ever run into this one before-plan to clean the contacts with some electrical connection cleaner, lightly coat them with some di-electric compound and see if that keeps the light off.
Any other suggestions.
Next question - Although it hasn't set a code, I was wondering if I had a problem on a '94 C3500, 7.4L NV4500 5spd. When I approach a stop and push in the clutch the RPMs only drop to around 1200, and then down to 1000 after about 5 seconds. It will not drop down to its normal idle speed (850-900) until after almost 45 seconds. I was wondering if I might have a sluggish (or sticking) IAC servo motor, a failing TPS - or maybe this is normal?
Although most folks seem to dislike the OBD and OBDII systems, I think they are great. All of the previous vehicles I have owned would NEVER tell you what was wrong with them, you had to go through a lot of diagnostics yourself and then sometimes result to easter-egging! I wonder how many Dodge owners have been taken in by the open ballast resistor?
Texas Truck - r
It's possible that the IAC is sluggish, but a vacuum leak is more probable, I think.
Wow, 100 degrees. I may pull 'er into the barn for some shade later this afternoon.
What do you use to snoop for vacuum leaks? I am out of carb cleaner (used it all up cleaning trailer wheel bearings). I have heard of using WD-40, but never tried it. You?
I suspected a vacuum leak, but I cannot remember why I dismissed it. Hmm, could be slipping in my old age.
Texas Truck-r
WD-40 could work, but would take a little more to detect the leak.
Know about memory thing, got tons of little notes everywhere, but can never remember where the one I need is. ha ha
Use a search engine and look for names like "Summit Racing" and "JEGS". Thet tend to have a whole range of goodies to perk up nay engine.
Texas Truck - r
It will need to be accessed thru a scanner.
Should be under warranyt, so what is the problem with having the dealer find the problem?
As for what could it be? Anything.
The list of codes is in the hundreds.
perry40; 2001 Hyundai Accent GS
Last time a solenoid broke on another car it was in the middle of winter. The check engine light identified it before it became too serious.
my comment: i believe that the "american car care" shop is nothing but a piece of junk auto repair shop. with their big apparatus and claimed competent mechanics didn't know what they're doing.
(does anyone know a website that is free for me to check my cars history plz e-mail me): shemz@onebox.com
i appreciate u allzez help
In the case of the latter, you will need to have the car diagnosed - your dealer is not the only place, though. A reputable repair shop (make sure they have Mazda diagnostic adapters for their scanner) can check out your car, probably cheaper than the dealer and if repairs are necessary, those will be cheaper, too. Good luck.
1) Use higher gas octane (93) see what happens..
2)CHECK Your GAS CAP if it is not secure in and iz not clicked at least 3 times the eng. light will come on!!!!(sensores)
3) Take out the negative wire in ure battery for about 2 hours or so...(this is what helped!!!)...This strategy should reset ure engine light and all the electronics in the car.
4)Do tune up change oil and spark plugs and all
5) be patient and calm.....you will feel releived after the light is OFF!
GOOD LUCK!!!!
Now, if the light turns off, who cares if the trouble code is still stored, right?
You will when a real problem arises and your mechanic spends that extra time, which you will pay for, looking for that phantom trouble code.
Do it right, repair the problem. If it is the fuel cap, that is fine. There are many scanner programs available for laptops and hand held scanners that are available on the market for resonable costs, around what it would cost you to go to a shop a couple times.
Five days ago, my muffler went. I had to attend 2 funerals over the weekend, so I brought it to a Cole as soon as I could. They had to order the part of course, but said they'd wrap it so it would be less noisy until it arrived. The technician noticed that there was a hole in the heat sheild- and behind that was my gas tank, which had a golf ball sized hole in it. They would not even start it to get it out of the garage. He said he was amazed it had not ignited. What should I do? I'm getting it fixed, but a muffler blowing through the heat sheild? doesn't that defeat the purpose of the thing?
I'm afraid to get into the van with my son even after it is fixed! Any ideas?
Anybody know if the codes stay in the ECM after it has been manually cleared.
Anyway, I replaced the EGR valve with a used one from an engine with 33,000 miles on it. The SES light came back on, however. I am beginning to suspect an O2 sensor. It looks like there is only one, and it is on the lower rear of the engine (on the exhaust manifold, to the left of the EGR connection).
For the mechanics out there and for those of you who may be familiar with this car, how difficult is it to replace the O2 sensor? It seems hard to get to and I can't see where the wires go from the sensor. Do the replacement sensors come with the complete wiring harness, or do you have to splice and crimp the new part to the old wires?
Thanks for any help,
Steve
Today, I took a tip both from this forum and a parts shop, and disconnected the negative cable on the battery for several hours. On the way home from work, the light did not come on. So, we'll see.
Steve
"Possible causes include defective solenoid, stuck solenoid pintle, wiring concerns, or (and this is a common one) one of the 3 EGR recirculation passages in the intake manifold blocked with carbon buildup."
So, if it's a stuck solenoid pintle, is there a way to correct this? Second, is there any way for me or a mechanic to somehow clear the recirculation passages without removing the intake manifold from the engine? Is there some type of an fuel additive that may do this?
Thanks again,
Steve
the code is 8. Can I know what that code means?
It was probably a combination of everything that was happening. Like the 400rpm idle, the cloud of white smoke that probably confused the hell out of the O2 sensor and misfiring.
