Need Help
bigdaddy1970
Member Posts: 5
Hope somebody can help me out with this problem. My wife's volvo started acting up when ud try and start it, ud have to turn it over 2 sometimes 3 times before it would start and I can hear the fuel pump kick on every time. This went on for about a week or so then Wednesday it would start but if u gave it gas or tried going forward or in reverse it spits an sputters and tries to shut off. I changed the cap and rotor & its still doing it. When it's running u can add pedal slowly and it runs but if u tap the pedal it tries to shut off. I replaced a couple sworn vacuum lines thinking it was a vacuum leak, but it didn't change a thing. When I turn the key to on and purge the fuel rail it just trickles out. When its running it half ways sprays. My question is, would the fuel filter cause this?? It seems u have to keep hitting the key for it to start because its only letting a lil bit of fuel get through and when theres enough gas built up it starts up and duns for a bit spitting and sputtering off and on then after bit shuts off. Am I on the right track thinking fuel filter?? I can hear the fuel pump every time I turn the key and just acts like its a fuel issue. I put a bug bottle of treatment in when it started this crap thinking we got bad gas, but hasn't helped. I replaced plugs, wires, and air filter in April for routine maintenance as well. Again, I can hear the pump working and if you add pedal slowly it will rev up and you can hold at higher rpms, but when you tap the pedal or put it in gear (adding load needing more fuel) it dies. ANY IDEAS OR HELP WOULD BE GREATLY APPRECIATED. Already paid for a cap an rotor that obviously I didn't need so didn't want to buy anything else without picking somebody elses brain. And with a collapsed right side of my spine and nerve damage I don't want to go through the physical pain of changing the filter which is a bugger to do on the AWD for nothing. THANKS in advance for any help given!!
Answers
