Visitor Agreement.
something is missing here.
It will then show what is happening when the check engine light comes on.
"P1556 "A" Camshaft Position Actuator Control Open Circuit Bank 1 (BMW)"
Dusty
Recheck the trouble code, as it is invalid.
was NOT aware that anybody has "secret maintenance schedules" for periodic maintenance that are not published, as that would be against the magnusson-moss warranty act as I understand it.
I strongly suspect the maintenance advisor goofed that part. it is possible to get incomplete sealing around valves, or have chunks of gunk break off and crack rings, so if you have a performance issue, it does need to be addressed.
the general decarbonization procedure I have heard of, and used to do periodically for no demonstrated good reason on a couple of old mopars in the 70s other than "clean is good," is to slowly trickle petroleum solvent into the carburetor throat, choking on the evil white smoke, until the car stalled out. then you turn the key off, go someplace else for a half hour or so, start the car, and drive a bit until you stop smogging out the neighborhood. there is probably a modified procedure for FI engines, maybe introducing what is essentially penetrating oil through a vacuum hose, because carburetors are hard to find on the engine these days.
Need to know what trouble code they got to come to that conclusion.
De-carbonizing is not listed as routine maintenance, so I guess you can draw your own conclusion from that.
Leaking fuel pressure regulator diaphragm ( a PITA, the upper intake plenum has to be removed to access)
But starting about a month ago, I occasionally get a "Check Engine" light for a day or so. Nothing seems wrong when this happens, and I make it a habit to tighten the fuel filler cap at least 5 clicks after each fillup. I can't make a direct connection between fueling and the light coming on. I know that it usually has to do with pollution control, and could just be a bad oxygen sensor or such.
I was wondering though if any other owners have had the light come on, and then just clear itself after maybe 3 to 4 starts. And if so have you had it checked to know what is causing it. It came on last Saturday when I was going to be close to a Mazda dealer (about 60 miles from home), but by the time I made a couple of stops elsewhere it had cleared so I just skipped the dealer visit.
Any idea on the cause of this? Is there a way to get "beep" code readouts without special equipment, and if so, where would I find a list of those codes?
Thanks for any answers.
Also, there is a TSB out advising not to use 93 in the P because of carbon buildup. Check post #2536 of 2584 by misty8
(Bulletin No: 01-027/02
APPLICABLE MODEL(S)/VINS
All 1995 - 2002 Millenia models with 2.5L V6 (KL)
Description
After a cold start, MIL comes on with DTC P0300 to P0306 stored in the memory. In most cases, this concern may be caused by misfire occurring in one cylinder during idle. The use of premium fuel (high-octane fuel) may be allowing carbon deposits to accumulate on the exhaust valve seat, causing momentary insufficient compression.
To correct this concern, remove carbon deposits using a suitable top engine cleaner.
Note: After removing the carbon deposits, be sure to advise the customer to use lower-octane fuel (87 or 89 octane) to help prevent future recurrences.)
And this is from AllData:
5- 0102702 APR 03 Engine - MIL ON/ DTC's P0300 - P0306 Set
http://alldata.com/TSB/33/02333664.html
I have a Nissan Altima GXE,1994.From yesterday I see the Check Engine indicator ON.I used to get this indicator when the car would stand under the Sun for few hrs.This time it happend during the night.It is ON there after.I started the car today in the morning,still the indicator is ON.No fumes,no smell though.
Can any one of you tell me what the problem could be.Pls include the apprx cost.
Andy.
My car has pinging issue. It was intense during summer time. It's got worse and I emptied 20 oz Chevron techron into half way full tank, sprayed 1 can CB cleaner and 1 can TB cleaner into TB towards upper intake, cleaned up the plugs with wire brush. BTW, plugs were nice and deposit free. The car picked up some power and pinging was gone.
200 miles later I heard light pinging. But today, after AZ erased the code, it pinged and I felt performance was down. I realized that now it is using more fuel. 3 quarters of thank I've got 160 miles. I used to get 21 miles per gallon in city. How the heck donwstream heated O2 sensor on bank 2 causes more fuel consumption?
I bought Autolight 764 copper plugs but haven't installed them. Also I am planing remove the upper intake, TB and all other thing along the way and clean them.
I am not sure whay O2 sensor is givin this much early problem.
I wonder whether CB or TB cleaner has any effect on O2 sensor problem. What you guys think?
Another thing that when I pull upper intake out and discover that lower one is dirty how I should clena that up?
The computer picks up signals from sensors, and uses the info to adjust timing, and injector pulse duration. If your O2 sensor is defective, it can cause your engine control sysem to pickup false readings, and send out improper commands to fuel, and ignition system. If your scanner is telling you that your O2 sensor has a problem, then that would be a good place to start. Sometimes the code is caused by a bad connection. More than likely the O2 sensor is bad. You can change the sensor, and take a chance that it's bad, or get a manual where you get auto parts, and look for one with a flow chart. That will tell you how to check each sensor for voltage and resistance in the wiring.
I think if I had the problem, I'd get the O2 sensor, and make sure the wire connection is clean.
I had to change all my O2 sensors at 8,000 miles. So your miliage is not unusual. Glad about having the warranty.
I belong to a Ford truck forum that includes Rangers with the 3.0 LV6, and the pinging is common. Most switch to higher octane gas.
His suggestion was to go to a slightly higher octane gasoline (I'm running 87) or have the computer reprogramed. I have no ping or knock even under hard acceleration, so I am going to put a couple of feelers out to see what online mechanics suggest. Thought I might get a bite here.
2000 Ford Taurus V6-183 3.0L VIN U SFI Vehicle Level Engine, Cooling and Exhaust Engine Technical Service Bulletins All Technical Service Bulletins Engine Controls - Spark Knock on Acceleration
Notes
Article No. 02-24-3 12/09/02
DRIVEABILITY - SPARK KNOCK ON ACCELERATION - 3.0L 2V/FFV ENGINE ONLY
TRANSAXLE - AX4N/AX4S - HARSH TRANSMISSION ENGAGEMENT - 3.0L 2V/FFV ENGINE ONLY
FORD:
2000-2001 TAURUS
1999-2000 WINDSTAR
MERCURY:
2000-2001 SABLE
Article 00-25-5 is being republished in its entirety to update the Service Procedure.
ISSUE
Some vehicles equipped with the 3.0L 2V or 3.0L FFV engine may exhibit spark knock during light accelerator tip in or heavy acceleration. 2001 2V and FFV Taurus/Sable vehicles may also exhibit a harsh Park to Drive engagement. This may be caused by the calibration of the Powertrain Control Module (PCM).
ACTION
Verify condition. Check for potential lean contributors, reprogram the Powertrain Control Module (PCM), and/or perform Octane Adjust. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Windstar vehicles: DO NOT perform PCM reprogram. Check for potential lean contributors and/or perform Octane Adjust only. Refer to the following Octane Adjust Procedure for details. If the spark knock condition, (2000/2001 Taurus/Sable), or transmission harsh engagement, (2001 Taurus/Sable) is still present after performing normal diagnostics, check for potential lean contributors and reprogram the PCM.
On a very small percentage of Taurus/Sable vehicles, it is still possible spark knock may be present after PCM reprogramming. If spark knock can be verified after PCM reprogramming, proceed with the following Octane Adjust Procedure.
Use the New Generation Star (NGS) Tester to perform an Engine Octane Adjustment using the following procedure:
1. Using NGS Service Card (11.0 level or higher) and Flash Cable, select "Service Bay Functions".
2. Select "PCM (Powertrain Control Module)".
3. Select "Module Configuration".
4. Select EEC V or PTEC Vehicle - by TSB.
5. Press trigger to continue on emission compliance authorization screens.
6. Highlight the Octane Adjust column and press trigger, then rotate the dial to change the ignition timing from "No Retard" to "Retard". Press trigger again.
7. Highlight Fuel Octane and press trigger, then rotate the dial to set the octane to 87 Octane and press trigger again.
8. Press the Start button. You should receive a message saying that the change has been successful.
NOTE FAILURE TO PRESS THE START BUTTON WILL RESULT IN CHANGES IN OCTANE ADJUSTMENT NOT BEING ACCEPTED.
9. Exit out of Service Bay Functions.
Obtain an Authorized Modifications Decal (FPS 8262 - obtainable through DOES II, 25/pkg) and list the date, dealer number, and summary of modifications performed. Select a prominent place adjacent to the Vehicle Emission Control Information Decal suitable for installing the Authorized Modifications Decal. Clean the area, install the decal and cover it with a clear plastic decal shield.
PCM Calibration Information
SUPERSEDES: 00-25-5
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage And Emissions Warranty.
OPERATION * DESCRIPTION * TIME
022403A * Check For Lean Contributors And Reprogram Powertrain Control Module 2000-2001 Taurus/Sable * 0.7 Hr.
022403B * Check For Lean Contributors And Reprogram Powertrain Control Module Then
Perform Octane Adjust Procedure 2000-2001 Taurus/Sable * 0.8 Hr.
022403C * Perform Octane Adjust Procedure Only 1999-2000 Windstar * 0.6 Hr.
DEALER CODING
CONDITION * BASIC PART NO. CODE
12A650 * 42
OASIS CODES: 497000, 503000, 504000, 615000, 615500, 615600
This is a 1994 Continental with 130,000 miles on it, but besides the beeping it still drives very well. Any suggestions?
Even my humble 99 Cavalier has one.
If your vehicle is pinging and there is a knock sensor installed, I would check the operation of that sensor. Disconnect the wires to the sensor and put a scope on the sensor terminals. With a small hammer strike a sharp blow next to the sensor where it is mounted on the engine block. Do NOT hit the sensor ! An AC signal of about 1 volt should appear on the scope to indicate a working knock sensor.
Instead, the knock sensor itself started causing the check engine light to come on at times. Mazda replaced it under warranty about 3 weeks ago and that solved the CEL problem. I guess the thing was just so sensitive that some minor vibration would cause it to send the signal to light the CEL.
I have a friend at work with a problem. She has a 97 Protege LX, 5 spd, L4, 1500cc, which is turning its CEL. I scanned it the first time, and found a P0505 - Idle Control problem. She mentioned that one time the CEL came on, the RPMs at idle jumped to 1000 (normally 700). I read that the IAC can be cleaned, and this sometimes fixes the problem. I reseted the CEL, and asked her to let me know when it came back, so I could confirm the code (she had left the gas cap loose one time, so I wanted to eliminate the obvious first...).
A week later, she told me the CEL came back on. I packed my scanner, and read the codes. The P0505 was there again, but this time she also had a P0421 stored. This has something to do with the catalytic converter not warming up properly (?).
My question is, can these two codes, P0505 and P0421, be related? Can something else be triggering these, like a faulty HO2S? There are no vaccum leaks, and the engine runs fine (I could not get it to idle fast when I drove it...). Any suggestions appreciated. I feel a bit bad, as she bought the car in part because I told her Protege's were great (I have one...).
TIA,
G.
Our state has just switched from tailpipe emissions testing to the OBD-II connector test. Just ignoring the light is not always an option.
for those wondering what the CAN protocal is, it is Controller Area Network and will replace OBD2. And yes, those of you who have OBD2 scantools, they will be obsolete, unless they are upgradeable, but most aren't. Good news, huh?
The dyno testing will go by the wayside and you will pull into an emissions test site, they will plug in, download the info and you will pass or fail.
if you have an commodore computer in the attic, it's also a paperweight. and they're trying to kill the CD now.
stuff happens, technologies change, the world moves on. if you want to keep the old stuff alive as a hobby, like rebuilding 1924 radios, cool, watch your favorite auction site for killer deals on barely-used scantools.
and if anybody finds any good used or NOS type-20 vacuum tubes, let me know, it would be nice to bring one to a local museum and maybe get a chance to play the original RCA theremin as a result.
If they are doing a safety inspection and passing a vehicle with an SRS or ABS light on, then they are taking a personal liability, not to mention breaking the law.
and geez, it all started after I complained about emissions stuff messing up on my 76 buick........
:-D
... but seriously folks, if you had lazy 02 sensors, it seems to me there's no way you could legally pass if the test was any good. and the CEL won't light up on lazy sensors, only open ones, right?
There are alot of variables that OBD2 doesn't account for, that CAN will.
My 86 Honda Prelude failed its emission test because of a lazy O2 sensor without me being aware that there was a problem. No CEL was displayed. But then it only has one O2 sensor and does not have OBD2.
When OBD2 came out it was said to be the answer to all these types of problems. It's like Microsoft software. Each new version has its own set of problems and bugs. I wait with bated breath for the next version of on-board vehicle diagnostic software/hardware.
Auto Zone
Thu Dec 18 09:14:55 2003
Auto Zone #3038
58400 Belleview Rd
Plaquemine, LA 70764
(225) 687-8854
Number Crossed : P0420
Cross
Reference parts found:
TROUBLECODE OBDII (ALPHA) P CODE
TROUBLESHOOTING P0420
The PCM has determined that the catalyst system efficiency for bank 1
is
below threshold for the current engine operating conditions. (Bank 1
identifies the location of cylinder #1, while bank 2 identifies the
cylinders on the opposite bank).
I understand that with neither he nor I being mechanically inclined, this will need to be handled by a professional, but what I would like to know is if someone could give me an idea what is the likely problem with this vehicle. To me, it would seem that there is a problem with the catalytic converter, something with the pollution abatement system. Does this look to anyone like this system may be getting "fouled", and if so does this usually require a whole new system installation?
Many thanks!
DTC PARAMETERS
The stage one will fail when the catalyst efficiency becomes less than 75% efficient. After stage one fails, the 50 sample test results are used by stage two. When the results of stage two are greater than the fail threshold mV (catalyst efficiency below about 70%), the MIL (SERVICE ENGINE SOON) telltale lamp will be illuminated and a DTC P0420 will be set.
Probable causes of a DTC P0420 are:
Exhaust system leaks between the front and rear sensors or rear sensor leaking.
Catalyst deteriorated due to excessive time operating vehicle with a catalyst damaging misfire.
Contamination of converter due to incorrect sealant, fuel, or fuel additive.
IMPORTANT: A catalyst monitor test will not be performed if a fault exists in the rear or front oxygen sensor circuits.
DIAGNOSTIC AIDS
DTC P0420, once set, should remain active. However, under certain driving conditions the catalyst monitor test may pass. This condition may occur if driving the vehicle at highway speeds (high air flow) but if the P0420 is set and no exhaust leaks are found the catalytic converter should be replaced. If a misfire (P0300) is detected P0420 test will not run. Be sure to correct a misfire condition before replacing the converter.
Also..I have had the exact same problem with 2 that's right 2 '94 Chevy Cavaliers. Both with the same 3.1 engines. (Each of my daughters had one.)
Is there a problem that Gm won't admit or is there something else that could be causing this. the EGR code is the only one that comes up.
Don't want to start putting $$$ into it now.
Any suggestions on how to start looking for the problem?
http://www.troublecodes.net/Ford/
Experience has shown that an intermittent check engine light on a pre-OBD II Ford is most often caused by a failed sensor for the EGR system. Typically sets an "Insufficient EGR Flow" code.
One other thing that may or may not be worth mentioning. While idling in gear the cars lights really dim and there appears to be a large draw on the battery guage. Believe it or not it has the original battery. Could this be causeing the issues?
Would a dirty EGR cause these symptoms? Where is this sensor at that monitors flow through the EGR valve? I did do a top engine clean with a product called Seafoam through the PCV inlet to the intake. With that and the new O2's the car gets better gas mileage, which is a good thing. Is it possible to extract the codes using a digital voltage meter, because that is all I own? Also I didn't see anything about the 4.6LV8 system/computer on that site. Did I miss something? Anyway thanks in advance for any information that you will be able to provide. I know I bombarded you with questions here, but I am loosing any hope in trying to help this car out.
http://www.troublecodes.net/Ford/eec-iv.shtml
Around 94-95 is when most automakers started switching to OBD II, so some of the info might not apply. The easiest way to tell is by checking the underhood white emission sticker. If it doesn't say "OBD II compliant", which I don't think it will for a '94, the info above will work. If you don't have access to an analog voltmeter, use a 12V test light in it's place and count the flashes. If it is OBD II compliant, take it to any AutoZone and have them read the codes (no charge). Don't buy anything, just post the codes.
The poor idle you describe sure sounds like an EGR valve hanging open at idle and introducing exhaust gas to an already lean idle mixture. It's parameters are:
-engine coolant temp above 156F
-throttle off idle
-not wide open throttle
Retrieve and post the codes, and we'll go from there.
