How to re- set keyless entry for 2004 used Lincoln Town Car? No info on that.
I bought a 2004 Signature Lincoln Towncar. .It only came with one key, and I was not able to get any information on the keyless entry ,when I bought the car from the car dealer..I read all the great solutions by forum members on the problem with water leaking into the rear passenger floor area of the Lincoln Towncars, that is happening with my car too.. So I was hoping someone could answer my question..My husband dropped the only key into the trunk today by accident and even though AAA was able to open it, as soon as they got in to the car.. the alarm system shut everything off and they were unable open the trunk by remote.. they had to take the backseat out to get into the truck to unlock the button on the inside of the trunk.the AAA towdriver recommended to get the keyless entry activated but nobody seems to know how to do that for the second owner after buying the car ...any suggestions please?? thanks, Ully
Best Answer
93tracker5spd
Member Posts: 194
Hello! There are two places to find the five digit factory code for your cars' key-less entry, it is unique to each vehicle. The first and easiest place to look is the right side trunk hinge bar, some are on a sticker, some are engraved and some are covered up with tape. If your model does not have it there, then remove the kick panel on the driver toe kick wall and look on the lock module box itself. This code only works with the driver door, then number 4 to open all doors and number five the trunk. You can then follow the set procedure to re-set a new code. Good luck.6
Answers
