2016 Nissan Titan XD Road Test | Edmunds.com
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The 2016 Nissan Titan XD is an all-new pickup that's larger and more capable than the standard 2016 Nissan Titan, which was also redesigned. Built on a stouter frame with beefier running gear, the Titan XD launches with a 5.0-liter Cummins turbodiesel V8 engine, crew-cab body and 6.5-foot bed only. A gasoline V8, extended-cab body and an 8-foot bed will be added later. It's a uniquely positioned pickup that attempts to split the difference between traditional half-ton trucks and the more powerful heavy-duty pickups from the Big Three.
Also, the article says "Nissan", but all of the pictures are of a Porsche. Word.
"The result is a Titan XD crew-cab diesel pickup with tow ratings that range from 12,314 pounds for the S 4x2 work truck to 10,608 pounds for a decked-out Platinum Reserve 4x4. A nicely equipped Pro-4X 4x4 can pull 11,784 pounds.
Those numbers put the Titan XD well above a truck like the Ram 1500 EcoDiesel, which has tow ratings that range between 7,540 to 8,870 pounds, and top heavy-duty trucks that can pull up to 17,000 pounds."
