Balance of Power — A Case For and Against the Four-Cylinder Turbo - 2015 Hyundai Sonata
Edmunds.com
Balance of Power — A Case For and Against the Four-Cylinder Turbo - 2015 Hyundai Sonata Long-Term Road Test
This update to Edmunds' long-term Hyundai Sonata details driving its turbocharged brother, the Kia Optima SX Turbo.
I suspect that Hyundai had originally rated the car based on a carefully prepped engine (like what Ford did with the 5.0 back in the late 1980's) and decided that the advertised power was writing checks that the average 2.0T just could not cash.
Plus power alone wasn't going to get people to choose a 4cyl Hyundai/Kia over a V6 Camry/Accord, so there was no reason to match the power ratings.
Hyundai/Kia doesn't need to compete against the niche V6 engines from Honda or Toyota. The take rate on them is less than 10%, and it makes the vehicle less costly to design it only for 4-cylinder engines.
I have a hard time imagining that this huge performance loss was accidental. So what is the point of this engine? What were H/K trying to accomplish here?
Question for Josh: The 0-60 of the new Sonata 2.0T has been recorded at 8 seconds by three individual sources (Edmunds, C&D, MT), which is profoundly pathetic and about a full second off what a 245hp engine should accomplish in a vehicle of that weight. Does it feel this slow in the real world, or is it kind of like a diesel with nice low range pull and nothing on top?
Second, while the 2.0t has less hp than the previous version, it's application is smoother especially bringing it up to speed. In the old model, you hit the gas and nothing happened until the turbo engaged.
