Well, there are two O2 sensors in 2000+ Tauruses. One before CT Converter and one after (bank 2) which is I am suspecting. This one only measures the exhaust temp and send the output to PCM. Should not have nay effect on gas mileage.
And I am not a big fan of replacing parts blindly. That creates more frustration. Since the light didn't came back I have enough time to fish...
Besides Vulcan engines are very famous for pinging, I have been reading all posts from different forums (Ranger 3.0 and Taurus). People change things left right but no clear cut solutions to this and very few of them got rid of pinging. However I believe this is related to EGR and upintake carbon built up.
O2 seems like OK now. Mileage went back to original which is 21 mpg in city. I think it is pretty good. I didn't know what was it, glitch or ... I am keeping eye on it. If it comes up again, will show no mercy, I change the sucker.
Cure: Change PFE sensor and fuel pump.
Reason: When it overheated, cut off fuel. When it cooled down, it works OK.
Cost: About $500 - 600
One of the few things on the car that drives me nuts.
PS - Don't let them try to lubricate the rollers...our guys did that (trying to do right by us) and now we get grease lines on the driver's window after repeated trips up and down.
What is most impressive to me is the absolute lack of any squeaks and rattles in this car-now at 30k miles and 3 years in service. Unlike what you might read about in the Honda Accord and Toyota Camry discussions. There is even a separate Camry Rattles discussion section.
I have been monitoring and participating at this site for quite a while and have seen very few reliability/maintenance issues on the current generation Taurus. Are they in general performing very well, or do we just have very few people participating in this site?
May be all of the above but there seems to be a great deal more people participating in Camry threads than in Fords'.
http://www.tauruscarclub.com/forum/
However, recent quality is way up compare with past generations.
When I mentioned the problem to the Ford dealer they told me that replacing both assemblies would cost between $500-700.
This seems to be a design problem, although I can't prove it. It's also happening to my '99 Plymouth minivan.
Do we have any suggestions out there for correcting this headlamp condition short of replacing the assemblies???
You might want to check out junkyards/used auto parts places to save some $ on replacement headlight assemblies for your Taurus, but you will have to look the used parts over to make sure they are clear enough and don't have any damage or signs of moisture leakage.
For reference I have a 97 and I've done the brakes for each set of wheels once. They each went over 90,000 miles.
I don't notice any change in my transmission and how it shifts. I have gotten a "Service Engine Soon Code,"of excessive slippage in the torque converter. That was at 71k. I'm at 98.5k and still on that tranny. Just had the code a couple of times in the last month. I didn't have it interegated; mechanic said it'll be stored in the computer.It could be a tranny code or maybe it's something else. Car runs fine. I'll wait and see if the light comes on again then I'll take it to the mechanic.
1) transmission not "quite" as smooth as it used to be, though I doubt anyone else even notices.
2) now that it's getting colder the steering wheel makes a slight groaning noise when cranked too far left or right - or turned too quickly. I've seen others post the same problem. Not sure what to do about it, but it's not a major issue.
Otherwise it runs very well and most people are shocked at how many miles I have on this seemingly "new" car. AND I leave it outside every day/night. The finish has dulled just a tad but then again I rarely wax it, only wash. Overall it's very comfortable and very reliable. If they could jazz up the looks I'd buy another one in a heartbeat.
Re: headlights. Is it possible you have a tiny stone chip/crack? That's happened to me before and you do have to replace the lens in that case. Since they're all fairly modular now it doesn't surprise me it would be that much. I'd search for a local mechanic that may be able to help you out...that part of the car is not rocket science. Good luck.
- R
My Service Engine Soon Light has come on twice in the past two months. It has gone away both times. The codes are stored; I haven't had the computer interegated.
As far as changing the filter every 30k, I don't know if it is necessary. I did mine at 90k. Mechanic stated my tranny and pan were extremely clean. I've done the fluid exchange at 30 and 60k so it should have been.
Maybe someone can give me some feedback. W/in the past 2 months at time when I go to pull my key out of the ignition it gets stuck. So I will turn the key forward, backward, and back to its position to try to pull out and it wont. It seems what I have to do is to start the engine again and shift into reverse, then back into parok and turn off and then the key will pull out "like its supposed to".
I am puzzled as to why there has to be some majicical way to get the damn key out???? God I hope its not that !!!! LOL
Thanks guys!
I admit I have not rotated tires as frequently as I should have, maybe every 10-12K miles, so the tires may have taken a bit of a "set" depending on rotation direction and perhaps some non visible tire wear or tire carcass shift has been affected by misalignment.
In any case this experience shows that tires and tire wear conditions can affect mistracking of the car, even though alignment may be within mfr's specs. Beware, mistracking is not always just an alignment issue!
This is an internal defect within the tread of the tire, and it's not necessarily visible in inspecting the car.
To their credit, General (who was the warrantee party, not Ford, which has changed) replaced the tire for me.
Moving the tires side to side or end to end can really help diagnose the problem.
Any ideas?
Makes you wonder if the problem was misdiagnosed the first time and the oil pressure sending unit was doing its job and the real problems was a failing oil pump.
That's a lot of miles in a short time! How has your SEL been otherwise? Keep us posted as the miles pile up.
I always change the oil at 3000 to 4000 miles intervals.
Thanks for your input. I guess I'll call a repair shop to have them check it out again. It frustrates me to pay their overhead rates and come away with the same problem. I can't take it back to the same Ford dealer since that's in Atlanta and now I'm back home (near Phila., PA).
I'm with you on the oil change inteverals, I change every 3K but put much less miles on in a year. It is cheap insurance, especially since I do it myself. I buy oil (name brands but I am not fussy on the particular brand) on sale with rebates for usually 59 cents a quart and filters (OEM Motorcraft) for usually less than $4. Each oil change costs me about $8-$9 per change, and it is more convenient than going somewhere else. I can change it on my schedule not some garage's.
My community has a recycling yard where I can dispose of the used oil, so I am not polluting the environment either with my waste oil.
If the pressure is truly good at higher RPM's you may be in luck. High pressure system pumps usually have a spring loaded relief ball as an integrated part of the pump assembly. It may have gotten stuck open and I would say dropping the pump is probably the next logical step. Also check to make sure there is no oil in coolant and no signs of it going out the exhaust from an internal failure that might direct part of it that direction.
My father had a chevy truck, 60's vintage, that would occaisonally flash the oil light at idle. They rebuilt at 12000 and again at 28000 as they missed the source of the problem the first time. It was some sort of internal oil line that had cracked.
good luck
Went out on Saturday, saw the coolant was low. Filled it up, and saw some coolant leak out, however, the tank is not completely empty.
Has anyone else experienced this? Anyone know what I should look to replace?
I have never had mileage below about 21-22 even in tanks with a good percentage of city driving, and this should be about the same whether you had the Vulcan or Duratec. My strictly highway mileage has always been in the upper 20's. Car is solid with no rattles, or squeaks even over rough roads.
My Taurus never had accessory related problems.
Sorry you had such a bad experience but I agree that a major part of your problem was a dealer who didn't give a damn. That's why, to me, there are so many considerations above and beyond the price you get when you are selecting a car dealer.
My wife's 2001 SEL is a great car and with just over 30,000 miles is still fun to drive and she still loves it!
Wife and I just purchased a new minivan and made it a Chrysler - unfortunately I'm still not convinced the Windstar (now the Freestar) is dramatically improved in terms of quality. But friends of mine that work at Ford (that admitted the Windstar sucked) say the new Freestar is a fine vehicle, but only time will tell. But my last two American cars: Grand Prix and Taurus both had >100,000 miles and both performed great. I am NOT a believer that you have to pay 20% premium for a foreign car to get excellent quality.
- R
