Visitor Agreement.
Do you have any suggestions? Do you think a double-side tape will work? Or should I use some kind of super-glue to seal it?
I think it must all be tied together some where and am wondering if anybody else has expiernced this problem.
Any help would be great
the front end has been replaced, power windows & moon roof now operate, power antenna functions and I even " cleaned " that pesky stop lamp switch that kept this car locked in park, blocking 2 other vehicles in my driveway. Now I have shifting problems, basically 3000 rpm revs before #1, drive or reverse engages from a dead stop. Fluid is clean and up to level. 2nd works fine, and I can shift into D or #1 once the vehicle is @ 5 mph. From my Chiltons diagnosis I am hoping this is either the Throttle valve control linkage or the transaxle control lever adjustments, but the manual describes the procedure BUT NOT their location. I thought I did find the TV linkage and adjusted it with no result, but with all the "spaghetti" under the hood, I'm second guessing myself. Help
I'll be happy see your answer for my question.
Can I found rear taillamp assembly for my Taurus 88'year, right and left.
Please, write me here, or mail: syntoco@online.ru
Alexander
Siberia
Russia
Krasnoyarsk
Did you find out what caused this??
(the code sticker for the wagon is on the "passenger side" of the fuseblock, under the dash, just to the left of the brake pedal. The sticker is affixed to the back of the block, and must be folded over to read the code. It has the five digit code, with the word "keycode" on it)
The problem: always have a KOER code 332 and same code set while driving maybe 1 in 20 trips and check engine light will stay lighted until the car is restarted.
I have inserted a tee and vacuum gage in line to egr valve. Vacuum is zero at idle as I expected. When I rev the engine and hold it, the vacuum will go to 8" and then drop to 0 in about 4 seconds. I guessed the vacuum should be steady and higher since I recorded 15" at the inlet to the control valve. I replaced the control valve with a dealer part for $45, but I was wrong.
I checked the voltage at the valve and got 14 volts always. The vacuum will change as described above but the voltage is constant. I did not expect this. Is the voltage switching on and off faster than my $10 radio shack multi meter can pick up? How is valve designed to work?
I replaced the EGR pressure sensor with a Wells part from AutoZone for another $45. In this case, the dealer wanted $105 and the parts person said they sold a lot of them. Any idea who makes these for Ford? Pep Boys sells a Borg-Warner part for about $55. This part did not help either.
Phase 3 included double-checking the hoses and pulling off the EGR valve. The valve opens and closes with a vacuum pump. I get exhaust out of the pipe and the little pipe to the sensor. I guessed I could feel vacuum at the EGR port. Should I get 15" here? I could make a fitting to measure vacuum with the valve fully opened w/ my vacuum pump. I want to verify the intake manifold passages are not blocked.
Phase 4 had a vac gage on the line from the egr control valve while the egr valve fully opened with 15" of vac from my pump. Now the vac was steady at 8" when I revved the engine unlike before. When I separately disconnected the throttle position sensor and egr pressure sensor I would get no vacuum. I don’t know what all this proved.
Any ides?
This may help explain the operation of the pressure-feedback controlled EGR:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_u- s/0900823d/80/0b/fb/e6/0900823d800bfbe6.jsp
Is this carbon in the throttle body or the intake manifold?
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_u- s/0900823d/80/0b/fb/e6/0900823d800bfbe6.jsp#hd1-1-2
I have a 98 Taurus SE with the 12 valve 3.0 Vulcan at 93K miles. It's the wifes car and driving it the other day I noticed it was missing slightly.
For a tuneup (spark plugs, fuel and air filters) the Ford dealer wanted $250 and the local mechanic about $160.
I'm somewhat able to turn a wrench and would like advice on things to look out for, do's and dont's when changing plugs myself on this Taurus. Should I change plug wires while I'm at it ? Where is the fuel filter and should I attempt to change it myself ?
In advance, I thank you.
The fuel filter is located under the car in front of the passenger side rear wheel. There is a big hose clamp holding it to the car and two plastic clips holding the gas lines to the filter. The new filter will have new clips in the box as the old ones break when you remove them. Make sure your car has sat a while to allow the gas lines to de-pressurize, and you will also spill some fuel, so be careful. I put a pan underneath the car to catch spilt fuel, and maybe a couple of golf tees could be used to plug them off temporarily, though I did not think of doing that myself at the time. It is a simple job, except for dealing with some fuel spillage.
Bad thermostat, which is stuck closed and limiting coolant flow, thus overheating the engine.
Plugged radiator core.
Electric cooling fan behind the radiator not operating properly.
The reason your car does not overheat as much when you are running the heater is that the heater core and heater fan is acting as a small radiator, which might just keep your coolant from boiling, but the engine still will run too hot.
Bottom line is you need overall cooling system inspection and maintenance.
I bought a 96 ford taurus a month ago. Today when I was driving back home I experienced the same things you described. The power steering thing freaked me out!!! did you solve the problem?
I have noticed recently that the ABS light doesn't turn on when you first put the key in the ignition. I also know that if there is an ABS malfunction that the light should either blink or be constantly illuminated (per Owner's manual).
Any ideas as to what/where you think the problem lies?
I pulled over and looked underneath the carriage and found nothing suspicious. PUt the car on the ramp and checked it, nothing major damage found.
Since I drove for about 300 miles and put another tank already. The needle never reaches to the top any longer. Please help. The people at Pep boys said could be the fuel pump. I can hear the fuel pump kicks in when I turn the car, however..
Help!!!!!!!!!!!!!!
I know it uses more gas but a warm up idle cannot hurt when it is really cold. All my cars run a minimum of five minutes in the winter before I start out. Then drive moderately until fully up to temp.
Take your car out and give it a good long run. Then if the light comes on get the fault codes checked.
All this presumes you have decent/recent ignition parts.
MERRY CHRISTMAS ALL!!!!!!!!!!!
Don't tell me this kept you up till 2:00 am. Hope not.
I used to recomend Mazda Protege, I own two but now I will not recomend that either because I have seen their new cars too, which is completly integrated into FORD US management! Hey, Ford management is loyal to their share holders but not their customers!
Stay away from any Ford!
I own two Fords now and have owned several in the past. I really cannot say I have had any more problems with any of then compared to any other make. I honestly feel that domestic sedans regardless of make are the most cost effective choices available for anyone who intends to keep a car for any length of time. Especially if bought one or two years old.
Friends of mine who swear by their Toyotas and Hondas keep real quiet when I give them a ride to their dealerships to pick up their cars....
So, try running your tank down low and refilling at a trustworthy gas station. You might also try some of the gas treatments made for the purpose.
