Three Ways to Brake - 2016 Chevrolet Volt
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
There are three ways to brake the 2016 Chevrolet Volt. You don't have to use them all, but using them makes sitting in traffic easier, creates a pleasant challenge and improves battery charge life.
This car doesn't have a manual transmission, and it has an electronic parking brake switch...so it just has a left pedal and a right pedal...there is no middle pedal.
If the EPB is applied while the vehicle is moving, the vehicle will
decelerate as long as the switch is held up. If the switch is held up until
the vehicle comes to a stop, the EPB will remain applied
Since regen is blended seamlessly with the brake pedal already, it probably makes almost no difference. I recall that Dan Edmunds though there was a tiny improvement in effiicency with L in the 1st gen Volt, simply from the reduced delay to engage it in stop-n-go traffic vs. applying the brake. I never saw any difference myself.
