2000 Ford Expedition won't start
so the other day I had a fender bender at about 20 mph it dented my passenger side bumper and broke my parking light but not my headlight I was able to drive about 5-8 miles then it shut down and still wont start something was leaking pretty bad not oil possibly antifreeze and/or tranny fluid any ideas why it wont start I could really use some help here
If it's not that, then you have to start a methodical diagnosis to see if you are lacking fuel to start, or spark to start.
One quick test would be to squirt some starting fluid into the air cleaner---if it starts and runs for a few seconds, then you have a fuel delivery problem. If it still doesn't start, then you probably have an ignition problem of some sort, or no signal to your fuel injectors. In that case, buy a simple spark tester from Autozone or Amazon.com, and test for spark as you crank the engine.
In any event, I wouldn't run this vehicle very far, if at all, until you find out the source of the leak---sounds like coolant leaking, given the location of your accident, but it could also be from a transmission cooler.
