Why I Didn't Buy One - 2016 Chevrolet Volt
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
I was going to buy myself a 2016 Chevy Volt. Here's why I didn't.
This is incorrect. It has the paddle AND it blends regen with the brake pedal. IIRC, in Volt 1.0, all braking up to about 0.3G was through regen. With a bigger battery, I'd expect the new Volt to do a little better.
Drive around in D for a while and check the front brake rotor temperatures. They'll be barely above ambient.
We (as a state) are so close to completing the Quick Charge gaps up and down California via the 101 or 99. When done, you'll only need to stop 2-3 times between LA and SF to quick charge and gas up. I just did the trip last week in my Leaf and stopped 8 times - quick charging most of the way. Range extending i3 with cult that in half if not more.
-mm
-mm
-mm
sounds like you can never really get comfortable in your daily driver. as soon as you do you have to give it to someone else.
also, if anyone has ever had a roommate that was a slob... kind of the same experience when it comes to a fleet car, but now you are sitting in their filth/stench. at least your cars are new and clean up pretty easily. sharing a 10-year old car with over 100k miles is no fun.
Edit: Per the manual, it cannot be changed, but you can program the unlocking portion. Very odd.
EDIT: I see that your following sentence clarified. It does not say the same thing as the first. Totally agree with you about the e-golf.
You must be monstrously big as I don't have a problem with this and I'm 6'2''
"2: Forward visibility: Not great. The front of the car is out there. Somewhere. It's got parking sensors that help, but I'd like a little more actual visibility."
It's really not bad at all.
"3: When you shift into drive, the Volt locks itself. I don't want a car to do that to me. There's no way to turn this off. (DB)"
And what happens when you put it in park? It unlocks correct? Why do you need to get out of the car when your in drive? I can at best see this as a minor annoyance but not a DB. To each his own. I do agree it should be programmable. Give the people the options! it's all software anyway lol.
"4: There's nowhere to put my arms. Just like with the Corvette, GM doesn't want my arms to have any space. On every turn, I thwacked either the center console or the armrest with an elbow."
Again you must be a monster. I'm 6'2'' and don't have this issue. You must also remember the class size of car you are buying. Perhaps you are looking at the wrong size of vehicle for your largness.
5: Too much chrome. Outside and inside.
Oh really?
6: Ride's not great over bumps. We pay all the taxes in the world here in California and the roads are all terrible.
It's no Cadillac but it's not bad either. I think people expect a lot because of the price of the car. But cars with this advanced of a drive train cost more.
"7: The front air dam scrapes over EVERYTHING."
EXAGGERATION
I actually like that it scrapes on crappy uneven roads. It means it is low enough to give the car good aerodynamic flow. Which means it efficiently cuts through the wind.
"8: There's no way to turn off the air-conditioning. You can disable it most of the time, but if the battery needs A/C, the whole car gets A/C. We've got cars today with multiple zones of climate control, each with its own fan speed. In the Volt, I'm at the mercy of a battery's temperature fluctuation."
Ok I call BS. Unless GM did something crazy since the 2013 Volt (I own one).
"9: Interior quality. All of the money spent on the Volt went to the powertrain and chroming some interior bits. The shifter feels hollow, the switches aren't great and the whole thing has a very low-rent feel. I could live with it, but I'd rather not. (DB)"
Yes the drive train is quite advanced. GM didn't want to price themselves completely out of the market. But I find the interior very livable.
"10: Style. Subjective sure, but this thing is tacky. Cool it with the surface treatments and brightwork, GM."
Now Gen 1 Volts were tacky. But this not so much.
"11: Stupid regen paddle. As Mr. Elfalan said, the Volt has a regen paddle instead of an aggressive regen system built into the brake pedal itself. Lifting off in the Volt is like lifting off in a normal car, not an EV. Further, the trouble with the paddle is that a brake pedal has many degrees of modulation and your foot is really good at using it. The paddle is on/off. It's like stabbing the brakes. VW's multi-stage, paddle-adjustable regen is an example of how to do this right."
I agree with the fact that the paddle should have more control of the regen. The Volt does have an aggressive regen in the brake. Like someone said drive it around for a while using only the brake pedal to slow down and after many stop the rotors are not hot. The regen is doing most of the stopping. You could also try putting the Volt in low if you wanted to try one pedal driving.
