Visitor Agreement.
Tracey
Need help in diagnosing a bad vibration in the frontend. It seems to happen when you apply the brakes while slowing down from a long distance. I've only had the car for a year (92 Taurus LX w/89k and yes the infamous 3.8L engine that hasn't blown the head gaskets yet) Anyhow, I've recently bought two new tires for the front had them balanced twice and installed new rotors and pads. I looked at the suspension and it looked okay, no broken or loose parts? Also, lately the brake pedal seems to stick, any news on this problem as well as the vibration would help.
If the vibration occurs only when braking then it could it be a sticking caliper piston or the caliper assembly does not slide smoothly on the guide pins. The sticking brake pedal may be a symptom of the caliper malfunction or it needs lubrication or maybe master cylinder acting up.
Is the floor mat restriction the brake pedal movement? Did you flush and bleed the brake system with new fluid?
I really appreciate the info, the problems with the vibration are tolerable. I didn't mention the fact that I just had the tranny rebuilt less than a year ago. Therefore, money is tight tight and more tight. I should take it to a professional shop but can't afford it right now. The Taurus was supposed to be my wife's car, but it had so many intermittent problems that she hated driving it to work. So it became my car. I've always been a ford truck man. A few Rangers and an Aerostar. They've always been good vehicles for me. The Taurus was the first and last front wheel drive Ford I will ever own. I'd sell it, but have too much money tied up in the Trans to just give it away. Besides the word is out about these early models Taurus' and the trouble they bring, i.e. bad trannys, head gaskets and A/C systems. So, who want's one?
Anyhow, I'll stop whining. Thanks for the advice and I'll check a few things on your list that I haven't already checked. I'm hoping that someone else out there has the same symptoms with their Taurus and can save me a lot of grief trying to trouble shoot this thing without spending a lot of money.
I have owned a few fords before too. all used vehicles.
1963 falcon - In my opinion the best ford I owned.
My first car, and had a 73 maverick 6 cly engine in it. routine maintenance.
No problems at all. Until the accident...darn it.
1983 ranger - 2.0l 4 cyl engine, 4 speed manual. I think a dozen hampsters would have been a stronger power plant.
Repairs.. Radiator, Rear wheel bearing , vacuum brake booster, timing belt broke in the winter of course -5 degrees(huh- whats a timing belt?) at least i was still in driveway, a year after timing belt the belt tensioner blew apart. left me stranded. And a bunch of other annoying things going bad. Nickle and dime me to death.
Gave up when it failed inspection for smoke.
Fix Or Repair Daily!!!!!!!
overall...not very impressed at all.
1983 ltd station wagon - annoying serpentine belt that always squeals, tranny that seemed to constantly search for gears, v6 engine seemed to run rough even with full tune-up. a/c needed recharge. Accident totalled it.
overall... not toooo bad, could be better.
I currently have a 1986 plymouth reliant, 2.2l 4cly, 5 speed manual tranny. Bought it in 1990 with 55k on the odometer for $1000. It has 145k now.
No "major" problems, never left me stranded (unlike the ranger).
Minimal maintenance performed. I thought this was going to be a "temporary" car when i got it. It replaced the LTD which was totalled in accident.
Repairs...Leaky radiator, heater core(this was worst problem),rear coil springs(sagging), windshield (big limb came down while driving...ouch!) Takes a lickin and keeps on tickin. The rust monster has a hold of it now, will replace during this coming year.
Overall..EASY to work on, great gas mileage, small repairs.
All cars had routine items like exhaust system, tires, brakes, battery, etc.
Go for another ford??? I don't know, very leery to try.
Enough whining for now.
Good luck with your taurus
Aftermarket chip connection Another cause of stalling if the car is equipped with an aftermarket chip, is faulty or deteriorated connections between the chip and the card in the computer. This can be fixed by removing the chip, cleaning the contacts, and reinstalling the chip.
MAF Connector and/or Speed Sensor Lee Hassig was experiencing this kind of stalling:
Well, this is the Maintenance and Repair conference, so it is natural that a Taurus topic here would be focused on Taurus problems.
If you use the Topic Search feature on the left side of this page for Taurus and again for Century you should be able to find topics in our Sedans (or other) conferences that will probably give you a more balanced perspective.
Also, I was wondering if you had discovered the Our Turn conference? It is devoted exclusively to women's automotive issues of all kinds. Town Hall is fortunate to have an automotive technician co-hosting it. She might have an opinion on one or both of these vehicles that I'm sure would be happy to share with you. If you'd like to check it out, you can click on that highlighted link to go there.
Welcome to Town Hall! Good luck in your search and your purchase.
Pat
gauge. It sometimes (not every time) goes
from 1/4 tank to empty with the dummy light on
within 5 miles. Later the gauge comes back
up to nearly 1/4 tank. At that time I add
12 - 13 gal. to a 16 gal. tank.
I have not become annoyed enough to take it
to the dealer under warranty.
So now.... has anybody been through this, or do you know what I should do? Thank You.
On a 86-95 Ford, check the left side of the trunk wall for an access to the safety switch. Press it back down and it reconnects the fuel pump.
Pat
The Turn signals & Hazard flashers do not work.
The fuses appear to be fine
Any thoughts?
Thanx
geo
I bought a '90 Sable (Mercury equivalent of Ford Taurus) new, just sold it 2 months ago with 135,000 miles. I would have been ahead by selling it at 60k -75k, but I hung on, pouring more money into it -- transmission, brakes, struts, cv joint boots, a/c, on and on (luckily I had the 3.0 liter - no engine problems).
Also starter, alternator, water pump.
Run, don't walk, away from those '92 Tauruses!
Ford Motor Company, you should be embarrased by this pile of trash that you produced.
Hello, & thanks Honda, for the car that I now own.
Our vehicles are all imports now -- Toyota, Nissan, and Volvo.
1) When Checking on belts I was posed with a question I could not answer. How can I positively ID if the 3.0 Liter is OH Cam or OH Valve. It shows both in the NAPA catalog
2) Should Timing belt be replaced now? How difficult in this engine?
3)Platinum Plugs- should they be replaced with exact replacement? Heard they are $8.00 each!!!
4)Tranny fluid- When removing pan to replace filter can the converter be drained as well? I was informed that one needed to have the entire system purged with a special designed pump- at Cost of $80.00 (Plus the cost of Pan/Gasket and filter change).
Thanks Ed
1. If the eighth digit of the car's VIN (serial number) is "U", then you have the 3.0-liter overhead valve "Vulcan" engine. If it's some other letter or number, then you have the 3.0-liter overhead cam "Duratec" engine.
2. The Vulcan engine has a timing chain, not a belt, and no maintenance is required. I think, but am not sure, that the Duratec engine also has a chain.
3. I'd stick with the platinum plugs - they'll last for 60K miles. I paid about $2 each, not $8.
4. I think you can get by without purging the tranny. On most cars, you can only get about 1/2 the total capacity out, so purging supposedly makes it possible to get ALL of the old fluid out. I get around this by simply changing the fluid more often.
I am not sure where the individual got the $8.00 fee from either. I happened to be in Wal Mart today and noticed platinum plugs in the $2-3 range. I will take your advice.
Also, I picked up my Haynes Manual- looks like it will help with most tasks I will undertake.
DO you have any advice on computer code readers for the Taurus?
Thanks again- Ed
http://cnnfn.cnn.com/2000/10/11/recalls/wires/fordrecall_wg/
Probably the best place in Town Hall to find others who have recently purchased that model would be over in our Sedans conference. Here is a link to the current topic over there:
Ford Taurus Two (Topic #3419)
Enjoy your new car!
Pat
The cars I am starting to look at now are Honda Accord and Toyota Camry. Ford has lost me forever as a customer; there shoddy quality and repairs, plus TOTAL lack of corporate attention to defects over the years far outway any initial cost savings.
The repair bills really did floor us
We have since learned
If you don’t want to get burned
Stay away from Ford and from Taurus
Problems included CV joints, brake rotors, engine mounts, front axles, tie rods, speedometer cable, transmission, head gasket and more that I don’t care to remember. Spent over $6000 Canadian in repairs over the 2 ½ years that this car owned us. The car was two years old when we bought it for $10000 Canadian. Ended up giving it away. Head gasket blew while I was having it looked at for trade in value on a Mazda. It saved the best for last – nice big smoke show right there at the Mazda dealership. I brought my concerns to the attention of Ford, whose only proposed fix was to sell me another Ford – not!. I will never ever buy another Ford. You couldn’t give me one if it came with cash in the glove box. I won’t take it. The 1995 Taurus Wagon was the junkiest car I ever owned. I am still paying off both the repair bills and the money I borrowed to buy it, and thinking about it and writing about it makes me feel ill. Keep away!
Occasionally, either after driving for a few hours, the check engine light will come on, and after a minute or two, go off, not to come back on. I am thinking to Oxygen sensor may transmit a problem. If the car runs fine, and your mechanic doesn't see a problem, I would not worry about it. Most likely it is just an emissions issue. I have been thinking about replacing the Oxygen sensor, as my mileage has dropped lately from around 24 mpg to about 22 mpg.
I have never had to do any transmission work, or engine repairs. One reason may be I flush both the transmission and coolant system every 30,000 miles.
All I can say is in my family's experiences with an 89, 92, & 93 Taurus, all have been fairly cheap to own. The 3.0 engine has a better reputation, but if I can get to 120,000 miles, I will be satisfied, as that would work out to paying $8,500 and getting 85,000 miles out of it.
I am changing the heater core in this beast on the weekend and would very much appreciate any help as my service manual is pretty vauge.
I understand its a big undertaking but it has to be done. This car has A/C but it hasn't worked in a few years and I have no intentions of having it repaired so thats not a big concern.
Does any one know if I need any special tools.
I was told that the steering column had to be removed, is this true? (Hope not!!)
Anyone one have any tips?
I would be greatful for any help.
You are lucky with those trannys. The "axods" trans have a rear sun/planet that gets starved for fluid, so they are not good cars to take on long trips. I am not saying that because I am not a Ford fan. They have a poor design (the newer ones are a little better) and the fluid gets hot and cannot properly lube the sun and planets on the rear of the tranny. You can tell if you need the radiator fluid changed. Take a multimeter and ground the neg lead. Take the pos lead and stick it into the antifreeze. If it's higher than .3 volts, time to thange it. Usually about every year or so is a good idea to keep the components properly lubed.
If memory serves me you will need to remove the dash and remove the entire climate housing to get the core out. I do remember having to unbolt and swing the column out of the way, but it wasn't hard to do that part. As I remember it was a difficult and time consuming job.
Let us know how it went.
