Transformed with 4.10 Rubicon Crate Axles - 2012 Jeep Wrangler Long-Term Road Test
Oversized 33-inch tires and standard 3.21-to-1 axles don't mix, so I upgraded my 2012 Jeep Wrangler with 4.10-to-1 Rubicon crate axles from Mopar.
I added a manual stab bar disconnect for less than $100 several months ago. I can't turn it on and off like you can, but using it is pretty painless and very effective. But I still don't have the Rubicon's 4-to-1 low range T-case. Mine is 2.72-to-1, the ratio that comes in a Sport and a Sahara. I'm not sure that bothers me much. I did quite a lot with the 3.21s in low range, and these lockable 4.10 axles should help a ton. I may change my mind once I get out there, but I doubt it.
Twitter: @Edmunds_Test
