Eectrical problem with the turn signals on my 1995 Dodge Dakota pickup.
comcoolcomcool Member Posts: 1
edited January 2016 in Dodge
the front turn signal dose not light and the bulb is good. It does not get power when the switch is activated. However the rear does. Can anyone help
    First thing I'd do is double-check that there is no power to the front turn signal bulb socket. If that's true, then you have to work backwards and probe along the harness. Sometimes connectors go bad, or wires break or short out.
