Check engine light
I have a 2012 Ford Fusion SEL. In late December, the check engine light came on (steady, not flashing). I took it to a local mechanic, as the nearest Ford dealership is a 45-minute drive away. He said an evap code came up indicating that there was a problem with the vent valve solenoid, not the capless fuel filler. However, he did not have the diagnostics to research it further.
As there have been problems with the vent valve solenoid, including a recall (for which we do not qualify), my husband bought and installed the part on Jan. 7. We both drove it several times since then, and the check engine light stayed off. But when I drove it today (Jan. 11), the light was back on.
Any suggestions as to what the problem might be? I suspect I will have to drive to the Ford dealership, but I would like to have some idea of the range of problems I might expect before I make that trip.
You might find THIS VIDEO interesting, especially around the 5.00 mark.
You should also watch the video on How To Maintain the Capless Fuel Filter
Update: Interestingly enough, the check engine light went back off last Thursday. However, as I'd already made an appointment at the dealership, I kept it and went today, to at least see what the code(s) said. The code that came up is P0451, indicating an evap system leak. They told me the specific problem is the fuel tank pressure sensor, which will need to be replaced.
The testing is pretty straight forward. Key On Engine Off (KOEO) Using a scan tool the tech has to access the fuel tank pressure sensor data and see if it is measuring atmospheric pressure or not. With the engine off and the evaporative test not running the canister and tank should be at atmospheric pressure. If the sensor shows something other than that, then the tech would manually open the filler, or command the purge valve on with the bi-directional controls which should bleed off any trapped vacuum or pressure. If the sensor doesn't show 0"water pressure (2.5v) then the sensor has lost its calibration and needs replaced.
Another question: The fuel economy on our 2012 Fusion SEL has been a little underwhelming. The EPA-rated MPG is 23 city/33 highway, but we've never reached 33. I do a lot of in-town driving, but even on stretches where we do more highway driving, the best we've been able to manage is 29 MPG. We keep our tires properly inflated and do other routine maintenance. Would a small evap leak affect fuel efficiency? I tend to think not, but figured it couldn't hurt to ask.
So statistically at least it seems like your car is okay.
I also checked the fuelly numbers for my car and I have to say they were right on the money.
