Stuttering problem
kimgentner2013kimgentner2013 Member Posts: 5
edited January 2016 in Chevrolet
Had new fuel pump installed low idle feels likes it gonna stall when I break or come to a stop been to mechanic 4 times he said all codes are clear also reaplaced fuel pump really added end sea foam please help don't know what to next
  • Mr_ShiftrightMr_Shiftright Sonoma, CaliforniaMember Posts: 64,482
    edited January 2016
    Lots of possibilities come up with stalling problems, from clogged fuel filter, faulty pressure regulator, vacuum leaks, IAC valve, bad injector, even a faulty ECM. Testing fuel pressure at the fuel rail with a fuel pressure gauge might be a good start.
  • kimgentner2013kimgentner2013 Member Posts: 5
    Thank you for your suggestions I am going to look to them all
  • tahoelt10tahoelt10 Member Posts: 6
    Having the same issues, fuel pump gauge fluctuating, transmission fuel stick broke, truck shaking, stabiltrak code up etc... Replaced fuel pump, fuel sender, and the volm manifold w/sensor which fixed most of the issues but now im having issues with the torque converter.
