What could cause roller rockers to not touch cam?
I have a 2003 Saturn vue. It had a timing chain guide break. And all the roller rockers came off the valves. After replacing the guid and resetting the timing the roller rockers aren't touching the cam. Any idea in what could be causing this?
Answers
It's highly unlikely that there is something else at play here. Even if this was the result of all of the lifters collapsing, they don't have enough internal travel to not have the cams applying some of the valves at any one position. Even then the lifters are spring loaded and they should be fully extended when released. How much space is there between the roller and the cam?
