Audi Residual Value Comparison
It seems that the residual value varies greatly between different models and trims. I'm looking at the A4 Premium Sedan which has a 53% residual value. I've noticed that different trims and other models are getting a much higher RV. I'm playing around with the numbers to see if I get a better price bumping up to a different trim given the higher RV. Does the A4 Premium Sedan have the lowest residual value?
Best Answer
kyfdx Moderator Posts: 269,398
Premium residual is higher than Premium Plus.. SUVs are usually higher than sedans.driver451 said:It seems that the residual value varies greatly between different models and trims. I'm looking at the A4 Premium Sedan which has a 53% residual value. I've noticed that different trims and other models are getting a much higher RV. I'm playing around with the numbers to see if I get a better price bumping up to a different trim given the higher RV. Does the A4 Premium Sedan have the lowest residual value?
Quattro is higher than FWD.
BMWs are higher than AudiEdmunds Price Checker
Edmunds Moderator5
