Car will start but won't shut down
                    Hello my daughter has a 2006 Rendezvous, she came home and told me her car wouldn't shut off so I went out and looked the key you could take out and it would still run so I pulled a fuse to shut it down, anyways I replaced the ignition switch which I thought it was the problem, no of course not that would be to easy so I went and got a new ignition lock and had her key mated to it went out put the lock back in and it started on the first try(always ran good) anyways I turned it off but it kept running had to pull a fuse again to shut it down to say the least I am dumbfounded now any one have any idea's to put me on the right path
First identify which fuse block terminal is the one that feeds power to the fuse key on engine off. (KOEO) With the problem occurring you need to measure across the fuse contacts with your volt meter's lowest setting. You will get a very small voltage, something on the order of 4.0mv ( .0040) or less in most cases. What is important for this first step is the polarity of the voltage in relationship to which connection for the fuse gets normal system power. Put the positive lead of your meter to the connection that should have power and the negative lead to the one that the fuse protects. Now is your meter reading a positive voltage, or a negative voltage?
A positive voltage means that power is being input to that fuse from another circuit that shares the same output from the ignition switch. A negative voltage indicates that the problem is being created by a failure on that protected circuit. This starts to narrow down which circuits need to be tested further and which ones don't.
I think I'd talk to the folks who did the power steering repair that their tech or they
themselves broke something and hid it instead of reporting it so it could be fixed.
And that it caused major problems which could have been even worse. LOL
Most wouldn't pick this off, but there s a common theme here. You assumed the ignition switch was the problem, and when that didn't fix it you then guessed that it might have something to do with the key. Then it was possibly a water leak damaging the fuse block. At this point blaming the shop/tech is no different than those other assumptions. Sometimes things just happen and it doesn't have to be any ones fault. FWIW. The power steering pump, as well as the power steering gear are both serviced from underneath the vehicle. There is nothing that would be done from the top that would be involved in either repair operation beyond add fluid. Suit yourself on that one. If one goes with the assumption that they have been falsely accused (remember no proof has been provided) what are they really losing?
