Can I charge my Miata's battery using a battery tender?
I have 2016 MX-5 Miata "Sport" trim. Is there a way to keep the battery at full charge by using a battery tender (trickle charger) attached to an interior receptacle? I know I can probably accomplish this by connecting the tender's clips to the actual battery but this would require me to leave the hood open. My tender has the necessary interior adaptor, but plugging it into the GPS receptacle does not work.
Best Answer
pauljay
Member Posts: 19
Mr_Shiftright: Thanks for your response. Unfortunately the port is not "on" after the ignition is turned off. So I guess I have no other options but to attach the battery tender directly to the battery, unless there is another port somewhere that I have not found yet.0
Answers
