The driver's window does not go up or down unless I keep pushing or pulling on the window button.
The driver's window on my 2010 CRV does not go up or down unless I keep pushing or pulling on the button. It used to go up or down with one push or pull.
Answers
1- Wires have come lose on the pw window modular on that side
2- Power motor is going
Since the other windows do work it is not a fuse issue.
Start the engine.
Move the driver’s window all the way down using the manual DOWN function of the driver’s power window switch.
Move the driver’s window all the way up using the manual UP function of the driver’s power window switch, and
hold it for 1 second after the window reaches the closed position
Let us know if that worked.
