DASHBOARD RATTLES
                    My '98 Buick Regal GS dashboard started rattling
several months ago. I took it in 2x without much
improvement. Finally, last week, I put it in the
shop for the 3rd time. When I picked it up most of
the dashboard rattles had stopped. However, I
noticed that the sides of the dash had been glued
to the piece below the windsheild where it curves
to the side. Does this seem like a long-term
solution or is the service department hoping to
appease me?? I know nothing about eliminating
rattles and need guidance.
The noise only appears when the temperature is around 10 degrees Celsius and disappears when it get hotter or cooler.
Until now, I've been using the old 'fist-to-the-dash' technique, but it doesn't always work.
With someone else driving, suggest that you first try gently push/pull/twist/etc the components in the vicinity of the squeak and use tape or trim adhesive to secure (or just reposition)any under-dash components that are suspect. If this doesn't help, I would next try the silicone spray. Be careful near the dashboard instruments; the spray could be unsightly if it got between the lens and instrument face.
Just one thing; I don't think that WD40 is silicone based, but it does seem perfect for dash sqkeaks.
look here: http://www.wd40.com/english/wd40q.asp
I was able to solve the problem. I discovered that the when the tilt steering is tilted up, something rattles, and when it's down, it's quiet. So I will keep it tilted down. (I prefer the lower driving position)
You have narrowed down your rattle considerably. There's a good chance you could remove the plastic shroud from the steering column and find the rattle.
A looped section of hydraulic brake tubing, located too close to another component, can create a loud metallic buzz ...I once experienced this and felt certain that the noise was coming from within the steering column. Troubleshooting took hours and the repair required three seconds.
My question is how would I go about solving this? With VW their bumper to bumper is 2yr/24000. Can I go in for service at any time during this to have the problem fixed, or is it only for the first year. What are manufacturers policies in regards to fixing squeaks and rattles on car under coverage?
Should I wait a while and see what happens, for better or worse, or bring it in immediately?
And Don't Wait! Get it in as soon as possible. Rattles never go away by themselves.
In most cars, you can find the fan by turning it on high speed while you look and listen beneath the dashboard. You will see the fan motor. Turn it off. The motor is permanently attached to a plate about 5-6" in diameter. Three or four screws hold this plate to the air plenun. Disconnect the wire and remove the screws. You can now lift out the motor, mounting plate, and fan-wheel as one assembly.
If cleaning doesn't do the job, it may be necessary to replace the motor. You can determine the need for a new motor by reconnecting the power (and ground) and running the fan while holding it in your hand. Keep clear of the rotating fan wheel and move the assembly through various positions to see if a motor noise will show up.
so, you must be one lucky customer.
Gosh, can't believe they wants to make rattling
mid-size sedan, Guess it's gonna be louder.
