Mazda Tribute Coil and Spark Problems
Hi everyone,
Please help. I have the 05 Tribute V6 with 59000 mi. on it. It has been running fine and smooth until last week. It refused to start. We towed it to the dealer. After a day, the dealer informed us the PCM was bad and they would replace it under warranty. We were so happy but not for long. The next day, they called us and said all 6 spark-plugs-coils misfired. And that's what killed the PCM. We have to replace them all before they give us the new PCM. The cost is $987 plus tax.
Do you guys think the dealer is correct in their diagnostic? Can spark-plug-coil-misfire kill the PCM? We have the car for 3 and half years. I have never experienced any misfire. The car has alway run very smooth averaging 21mi./gal in mix driving (70% highway, 30% city). Although, I've always thought this Tribute was harder to start than average. I have to turn and hold the key for 2 or 3 seconds to start it. My other cars take 1 second.
Thank you in advance for your opinions.
Vic
Vic
Were the misfires in the computer error memory before of after the PCM was replaced? If before, then whatever caused that set of messages to be logged in could have caused a PCM failure. However, if the error messages were logged in after the PCM was replaced then the problem could be the new PCM.
Is the dealer certain that the original PCM is faulty, especially in light of the misfire error?
The vehicle computer modules are robust devices and do no break that often.
When we get the Tribute back, it starts immediately (1 second) instead of 2 or 3 seconds as always before. And it feel a little stronger and smoother than before.
I think the old PCM has always had a small defect from the start from the factory. It just finally died after 3.5 years. And the misfires were just a common problem with this model. But that is hard to prove.
Again, thank you for your reply.
I've been working on vehicles as a shade tree mechanic (for fun no less) for the better part of 20 years, and had never heard of spark plugs causing PCM failure. On the other hand, I spent 8 years working in electronics and saw how sensitive some components can be, particularly to operation outside of their intended range. In my opinion, either the plant got a really bad batch of plugs in 2005, or the coil packs are too sensitive to impedance/load variations.
Whatever the case, you may be able to petition Mazda about the coil costs, since a TSB apparently exists for the spark plugs and their potential for damage to the coils.
I just had the exact same code, on the same car, 02 Tribute ES V6. I had all the parts (coils, plugs, gaskets, pcv) ready to do the change in the spring. But it had to be done now, so I had a mechanic do it with my parts. It's just too cold to work outside now.
thanks again,
The Mazda dealer suggested that I have them replace those 2 ignition coils (I assume there is one for each cylinder?) plus all of the spark plugs and wires. I have 85k+ miles and bought it used at a little over 60k, so it's possible the plugs/wires are original.
I was quoted $575, which they reduced to $520 for parts and labor with this job. That seems pretty high. Does anyone think I should attempt it myself? I am not sure about the disassembly required for 3 of the the plugs, and I have limited tools.
If I decide not to try this myself, is it something any decent non-dealer mechanic worth their weight in salt could do so I don't sink a half grand into it? I live in the Detroit area, so I figure there are plenty of gearheads to be found in a rough economy.
After taking it to the Mazda Dealer,they said that I need to replace the #1 and #6 ignition coils . The idle and misfiring problem I have feels very similar to when I replaced the IAC valve, which was easy and painless. The check engine light never came on either time, which surprised me. When these symptoms occur, is there a good way to rule out the IAC vs the Manifold gaskets vs Electronic Sensors vs ignition coils/spark plugs/wires? It seems like these tend to be the likely culprits.
The Mazda dealer suggested that I let them replace those 2 ignition coils (I assume there is one IC for each cylinder?) plus all 6 of the spark plugs and wires. I have 85k+ miles and bought it used at a little over 60k, so it's quite possible the plugs/wires are original.
I was quoted $575, which they reduced to $520 for parts and labor with this job. That seems pretty high to me... or am I being unrealistic? Does anyone think I should attempt it myself? I am a novice but fairly technical. I am not sure about the disassembly required for 3 of the the plugs, and I have limited tools... so I am leaning against that option.
If I decide not to try this myself, is it something any decent non-dealership mechanic worth their weight in salt could do to prevent me from sinking a half grand into it (and maybe still have the problem)? I live in the Detroit area, so I figure there are plenty of gear heads to be found in a tough economy that would be happy for the work at a better price.
at front 4,5,6 from passenger to driver looking from front of the car and
at back 1,2,3 from passenger to driver looking from front of the car
and it shuld also be written there. close to the coil wires.
Jeanette
I just sold my 2005 Mazda tribute to Carmax and bought a Toyota Camry. But before, I sold it, the svc dept at the Mazda dealership said that I either needed a new catalytic converter or I had an exhaust leak. I had been having problems accelerating, etc
Take to auto parts store and get free scan done, to make sure you have no misfires.
Going through same stuff for over a month now.
I have been using aftermarket coils because the price is too high ($114 each) for factory. The factory part number for the 2005 Mazda Tribute Coil for V6 3.0L is 1L8E-12A366-AB.
Does anyone know the resistance settings as I have an extra one I want to test? I need the OHM range so I can test with my Multimeter.
Any help would be greatly appreciated.
It happens to me twice in my escape 2005, looking around the web and found this article that explains very well the problem and how to fixed http://easyautodiagnostics.com/ford/3.0L-3.8L/testing-the-escape-cop-coils-2
hope this can helps.
