radio problems
recently I pulled the fuse for the radio in a 95
voltswagon jetta. The radio which worked fine
before, now only says (digital word) SAFE. I have
tryed new fuses and still get no sound and the word
SAFE still appears. Does anyone know what the
problem may be.
problem may be.
If it does same number with engine off - radio itself may be bad. Check also antenna connection and ground connection on the radio and around.
Does anybody have a clue what is going on? I told the dealership to put a fixed stick antenna on the car but he is hesitant and is saving that as a last resort.
thanks,
marv t.
Any help would be appreciated
project the music as if it were in the background. Music
that I'm very familiar with does not sound right. It
sounds distant. I've played with the BASS, TREB,
MID RANGE, FRONT BACK, and BALANCE for hours with
no luck. How can I determine if this is a faulty system or just
the way it is for this automobile?
Your help is appreciated. Thanks,
Joseph
in Vermont
Also, how easy is it to replace the stereo with a cd receiver? Should the reception problem be intrinsic to that particular receiver, I'd like to put a new one in, with a cd player, but am uncertain to the wiring considering the 6 speaker configuration. Any and all help is appreciated!
Chris
Pat
is apparent only on rough roads. The question is,
how does one get to the radio to remove and possibly fix the rattle? The radio/tape/cd was
added in Houston where the car was delivered from
the factory. The car has the "wood grain" interior.
How does one get to the radio?
Pat
On my car, the dashboard trim panel/s have to be removed first. The radio is mounted in a plastic panel which is removed with two screws, then the assembly slips out.
your new host, Bruce
the cd player skip. i went to dealer to replace it. until now i have not heard about them. i call them up. they said its back ordered....toyota said its a premium sound and it skip ???
help would be appreciated.
Did you get yours replaced? Are you still waiting? If you did get it replaced, DID IT FIX the PROBLEM????
Michael
I am looking for information about power system, creating high freqency, pitch noise.
I have ZX3. I noticed this noise from on the drive side, under the hood. When ac is on, I don'r hear that noise. I remember I used to hear hissing noise when I accelerated. But I forgot about it. Or I just didn't hear it any longer. But today, I turned on radio. And here was. I thought I got bad station or something. This wasn't it.
I don't know how radio/ cd player, not clock; when the radio is off, it shows time, digital; can create this kind of problem.
Do you think my car wasn't charging the power not enough? If so, then it should make the noise, when ac is on. Do you think it is a bad radio/cd player? Then why does it make noise much worse when I accelerated my car?
Any idea?
Some of you can probably find other topics on your specific vehicles in some of our other conferences (Sedans, Vans, etc.) where you are likely to find other owners of your vehicles.
If you want to pursue this, just use the Topic Search feature on the left side of the page for your vehicle's model name.
And if you get answers, come on back here and let us know!
Pat
thanks,
Any ideas on how to rectify the problem?
I bought a Honda Civic EX 2001 two weeks Back, and
the CD Player goes CODE Frequently and my Dealer
tried to fix it but Still I have this Problem. The
dealer said he has to talk to honda to find out
what should be done. I am wondering if anyone has
or had this Problem. Could you advice what I should
do incase the dealer takes more time to Fix this
and I dont get Proper response from him.(I have
been given a 5-Digit no. to activate the CD When it
goes CODE)
You might want to take a look at our active topic on Honda Civic Problems (Topic #912).
Town Hall is fortunate to have an experienced Honda tech hanging out in that topic and he may have an answer to your question.
Pat
