2016+ (third gen.) Honda Pilot Issues, TSB's, and Recalls....
                    Well now that the redesigned Pilot has been out for a bit, let's open a thread for discussing any Issues, TSB's, and Recalls. I know a lot of people don't realize that things might happen with their vehicle until it's too late. This thread will be used for spreading our (actual owners) knowledge and solutions.
Odie
Odie
I myself have a 2016 Pilot EX-L/RES in the Dark Metallic Gray. He has been named Smoky (you'll always see me refer to him by that name.) At purchase the Towing package (still waiting on the ATF Cooler), Roof Rails, and Cross Bars were installed.
For recalls, I have already been notified and have had fixed the Recall concerning the Warning Lights in the instrument cluster.
Just this past Monday I had found out about Recall 16-021A concerning the front trim on the roof (with and without the Roof Rails). Honda is replacing both front moulding (the little plastic piece) pieces. I had not received notification about this, but called my local service center. They confirmed the recall and have already scheduled Smoky for his repair. (see attached picture as to what happens to the trim piece before recall)
I has also found out there is another TSB (possibly soon to become a recall) concerning the FM Tuner. The sound quality fluctuates when on FM and volume can increase without warning. Beginning in May, Honda will start replacing the FM Tuner / Head units (radio) in all Pilot's.
Odie
Odie
(sorry, I haven't been posting much. Lots going on here.)
I've been hearing talk about water leaking in from the rear hatch into the underfloor area. I personally haven't had this issue, but have been keeping an eye on it since I have a full road side / towing kit system installed in mine.
Still no appointment for the repainting of rear roof / hatch yet.
Odie
Odie
While I working on cleaning Smoky (my '16) I found three little black pieces under the middle row seat. I looked under the seats to try and figure out where they came from. I found that the plastic caps for the end of the Slide Track has broken off on not one, but two of the tracks. I took a couple pictures and called my dealership / service center. I texted them the pictures so they would know what I was referring too while speaking to them on the phone. They will try to figure out what the part is since it is not showing up on the parts inventory list (except for the entire Slide Track) and will order to replace both pieces. I don't know if this cap stops the seat at the end of the track when it slides forward, but if it is meant to and it is broken, I can see the seat coming out of the track and causing injury.
I'll add the pictures to this so that you may see as well. Keep an eye because how many people just take their vehicle through a car wash and the pieces could easily be sucked up in the vacuum systems and you would not even know it happened.
Odie
Broken pieces found
Drivers side middle seat slide track, broken end cap
Passenger side middle seat slide track, broken end cap
"I am a little disappointed at my local dealership / service center (Ciocca Honda of Harrisburg). I took my new '16 Pilot EX-L/RES (Smoky) in yesterday (4/22/16) to have the ATF Cooler installed (missed by dealership when ordering the Towing package), the Front Roof Rail Molding replace (keeps popping out from window and has been in 3 times prior), the Rear Roof & Hatch repainted (damaged from improper roof rail instillation), and the Rear Seat Slide track repaired (end cap clips broke off when seat slide forward). They told me they will need to have my vehicle for almost an entire week and they had quoted me "They do not give loaner vehicles for any recall or service work." I was then referred to Enterprise Rent-A-Car to procure a vehicle until my NEW '16 Pilot is ready and I will have to cover the rental out of my own pocket. At a week of rental, I am looking at between $350-$500 just for a rental vehicle out of my own pocket. When did it become practice for Honda not to issue a loaner vehicle when major service / body work needs to be completed? I guess this is how "Loyal Honda Customers" are rewarded for being repeat multi vehicle purchasers. I will also be documenting this via Twitter and Edmunds.com along with this post.
Thank You for taking the time to read this."
Odie
Odie
I just discovered floor in the second row soaking wet, trying to figure out where it came from.. bletch
The trunk is dry...
Odie.
Havent experienced the water leak from the rear trim to this day yet..or the smell of gas but i will definately bring it up to the local dealer.
I have had some weird stumbles(possible transmission) slippage while accelerating at around 2k to 2500rpm..intermittently has only happened 3 or 4 times but taking it in to local dealer soon.will give update after service.
17-009 - Product Update: 2016 Pilot 9-Speed Transmission Warmer
techinfo.honda.com/Rjanisis/pubs/SB/AH/A17-009/enu/A17-009.PDF
17-011 - Product Update: 9-Speed Transmission Warmer (Transmission Previously Replaced for Transmission Warmer Leaking)
techinfo.honda.com/Rjanisis/pubs/SB/AH/A17-011/enu/A17-011.PDF
17-035 - Warranty Extension: Transmission Chirps During 3-4 Shift, Poor Shift Quality, or Engine Overheats Because of Defective ATF Warmer
techinfo.honda.com/Rjanisis/pubs/SB/AH/A17-035/enu/A17-035.PDF
16-013 - High Pressure Fuel Pump Chirps
techinfo.honda.com/Rjanisis/pubs/SB/AH/A16-013/enu/A16-013.PDF
16-021 - Product Update: Roof Molding
techinfo.honda.com/Rjanisis/pubs/SB/AH/A16-021/enu/A16-021.PDF
16-025 - Audio Unit Volume Fluctuates
techinfo.honda.com/Rjanisis/pubs/SB/AH/A16-025/enu/A16-025.PDF
16-054 - Timing Belt Chirps
techinfo.honda.com/Rjanisis/pubs/SB/AH/A16-054/enu/A16-054.PDF
16-071 - Window Glass Moves Slowly
techinfo.honda.com/Rjanisis/pubs/SB/AH/A16-071/enu/A16-071.PDF
16-076 - LKAS Does Not Keep Vehicle in Detected Lane
techinfo.honda.com/Rjanisis/pubs/SB/AH/A16-076/enu/A16-076.PDF
16-087 - Transmission End Cover Leaks (9-Speed A/T)
techinfo.honda.com/Rjanisis/pubs/SB/AH/A16-087/enu/A16-087.PDF
17-014 - 2016–17 Pilot: Judder from the Torque Converter Lock-Up Clutch
techinfo.honda.com/Rjanisis/pubs/SB/AH/A17-014/enu/A17-014.PDF
17-015 - 2016–17 Pilot: Judder from the Torque Converter Lock-Up Clutch After Software Update
techinfo.honda.com/Rjanisis/pubs/SB/AH/A17-015/enu/A17-015.PDF
17-021 - Safety and Emissions Recall: 2016 Pilot Fuel Tank
techinfo.honda.com/Rjanisis/pubs/SB/AH/A17-021/enu/A17-021.PDF
17-036 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
techinfo.honda.com/Rjanisis/pubs/SB/AH/A17-036/enu/A17-036.PDF
17-083 Hood Flutter or Vibration at Highway Speeds
techinfo.honda.com/Rjanisis/pubs/SB/AH/A17-083/enu/A17-083.PDF
These are all PDF's, so you can print them out and take the copy with you to your service center.
Odie
