Charging/Electrical problems with 2005 Kia Amanti
Car needs to be started everyday, sometimes less or battery goes dead. New Battery, about 49,000 miles. I have removed the trunk light and the glove box light...hoping to relieve the drain on the battery. Does anyone else have this problem, and what did you do to alleviate it?
I really like this car - please advise
SharonA
SharonA
Answers
Presuming the battery is not that old, and presuming that it tests as "OK" in a load test, then the next step would be to test your car's electrical system for a "parasitic drain". Using a volt/ohm meter with the engine off, key off, and making sure that no doors are open and no accessories are on, you should read an amperage draw on the battery of no more than around 50 milliamps, more or less.
There are lots of videos on YouTube explaining how to conduct a Parasitic Drain test.
