Premature failure of Chrysler Water Pumps
Just wondering how many folks out there have
experienced Premature failure of Chrysler Water
Pumps. I have a 96 Dodge Intrepid that over heated
and was towed several times and the pump was
replaced in August of 97. Currently, I am
beginning to experience the same symptoms. Also,
I'm wondering if the replacement pumps had
modifications that would preclude repeat failure
from the same cause. Per conversations with
mechanics, other local owners and e-mail on the net
this seems to be a wide spread problem. Per the
DiamlerChrysler Customer Service Center, they have
not logged any ongoing problems.
The car overheated once before the original pump failed -- either because of a thermostat or a piece of scale caught under the coolant tank cap seal.
At any rate, the pump failure was not obvious -- overheated engine, low coolant, but no visible leaks.
First clue was slightly elevated engine temperature, probably because the system wouldn't pressurize.
Excellent car in all ways except component quality! By the way, odds are good that your transmission will fail early due to the engine overheating. Mine failed at 80k.
Record: One inner and one outer tie rod end.
Funky power steering response -- lasted about 20k then got better.
Suspension clunks -- terrible!
Air Conditioner Compressor clutch tried to catch fire -- new AC compressor.
Air Conditioner condensor failure. New condensor.
Water pump.
Thermostat.
Front DB rotor warpage.
Currently, EGR fault check engine light all the time -- probably carbon build up in EGR tube buried on back of engine!
DMK
I may dare to say it was kind of nice that it failed because one of the transmission fluid cooler lines started a slow leak as well. I paid for it because it didn't think it was considered part of the powertrain. After finding out that the water pump failed and I knew it was covered under the 7-year warranty, and with some faxing to Chrysler, the 7-year warranty was re-instated and as it turns out, Chrysler is going to refund the cost of the tranny cooler line repair as well. Whoo hoo! (And I thought of changing the cooler line myself.)
"Government engineers analyze the problem. If warranted, the manufacturer is asked to conduct a recall. If the manufacturer does not initiate a recall, the government can order the manufacturer to do a recall.
We do not have to receive a set number of reports before we look into a problem. We gather all available information on a problem. Your report is important to us."
http://www.nhtsa.dot.gov/cars/problems/
New extended life RED/Orange Antifreeze does not contain borates or silicates which react with chemicals in tap water forming new chemicals which eat aluminum.
Only use distilled water in aluminum engines and batteries for long life. Flush every 30k even with extended life formulations.
Q45man
TRANSMISSION x 2 (it is still figuring my driving style) some call it 'hunting'.
BRAKES( front at 35000.mechanic says most folks have problems at 20,000 or less --WE ARE TALKING ROTORS AND PADS $250 average out of pocket.
AIR - under W.
I love the car,comfort,etc. BUT--- Will I buy one of their new wonderful designs???
I recently test drove the new LHS. The brochure advertised 'a dry engine'.Under the presence of the sales rep, as I opened the hood,oozed oil was very evident on the top plastic covering.
New fuel rails at about 50k.
Now the water pump. Last summer the car overheated but the mechanic couldn't find the cause. Three weeks ago (68k) my daughter s driving it on 200 mile trip when it overheats and blows a head gasket - caused by a failed water pump. The head is warped and remilled. $1,600 later I drive it away.
Warranty expired at 36k. Is Chrysler honoring any water pump problems after expiration of warranty?
Has any one run into problems of burning oil after a major overheat?
I talked to a mechanic and he said the "weak links" in the Chryslers were the water pump and transmission. I ran the VIN#'s on it, and found that the water pump was replaced in '98. The one thing that is holding me back from buying this car is what seems to be the inevitable- the tranny going out on me right after I buy it.
I guess what I want to know is does anyone have any advice for me? Do I take the chance?
in total the repairs on the 2 cars were as follows- 2 transmissions,1 alternator, 1 engine computer,1 catalytic converter, 1 gas pump, both had defective polycast rims which resulted in the loss of several center caps each costing $40, 1 abs module,defective rubber window seals which attached themselves to the window and travelled with it,transmission cooler lines,and a multitude of electrical switch problems.many of these problems were described in chrysler technical service bulletins, so they were known to the dealer and chrysler.i now drive an intrigue and 2000 subaru, and doubt i'll ever purchase a chrysler product again.
