Problems with 99 VW Passat GLS
I have a Passat GLS w/auto I purchased at Thanksgiving. I have 3 problems with the car (or at least I think they are problems) that I wanted to run by this message board to make sure I am not over reacting or expecting too much from the car.
First is the lack of torque from the engine after it shifts. Basically I drive the car rather mellow, that is I don't race or accelerate rapidly from a stop. What happens is when in auto and the car shifts there is a slight, but perceptible loss of power and speed. I've driven automatics before but have never felt this before (is it because it's a 5 speed auto?). It becomes an issue if I need to accelerate right after the trans has shifted. The engine tends to "bogg" down until it builds up enough torque. If I recall right the tranny tends to shift at around 2200rpm and drops to 1700 after the shifting before building up.
My question is - is this the right point for the tranny to shift? The only thing i can think of is that the tranny is shifting to early. Is this normal? It has this problem with every shift except between 1&2. If I shift the car manually (via Tiptronic) and keep it in gear slightly longer it feels fine - more like my previous experience w/automatics. I did not test drive this particular car and only test drove the one i did drive in the manual tiptronic mode
The other issue is the famous "choking" that a car gets when you hit the accelerator and nothing happens for a beat. It seems to be limited to when the engine is cold and I notice it when turning a corner as I decelerate and then accelerate after the turn (I shifting problem again?). Does anyone else experience this when the engine is cold? Is it because the turbo is not up to operating temp? I
Last but not least is a rattling coming from the right side of the car when the right wheel hits a certain kinda bump. It not there all the time only on some bumps. I think this topic was covered already
Does anyone have similar experiences with their Passat concerning the lack of power or am I expecting too much from a little 1.8T
Thanks for any advice
Joe
Did you realize the Passat's automatic is controlled by a computer chip which "learns" your driving style. If you "drive the car rather mellow" most of the time, the tranny picks up on this and adjusts it's shift points accordingly.
My best advice would be to learn to use the tip more, or learn to anticipate when you'll need to stomp on it, and stomp earlier.
--Mike
The triptronic is a ball. The V6 is a bit tough on the gas but part of that problem is my heavy foot. The trunk space is excellent, seats are very comfortable,(get the leather with heated seats ohhh ahhh)and I think it handles great. I made the deal via e-mail. I could not be happier. This is the car in which you will get the most for your money. I have.
This occurs primarily in the process of decelerating, turning, and then accellerating. On acceleration, gears don't move up, resulting in some unnerving traffic situations. Have to shift over to Tiptronic to get the car moving.
Last week, Dealer looked at the car, cited computer problems, and made some readjustments. Engine revs higher...problem occur more often. Service manager says it could be my driving style (yes, I know about the chip which supposedly tries to adjust to individual style). I stomped on the gas, drove like a granny one day, a Kamakazi the next...still have the same problem.
I consider this to be a rear-end accident waiting to happen. Back to the dealer today. Any ideas, thoughts, suggestions?
Tight as a drum, no squeaks or rattles. I LOVE this car.
Weight: 3122 lbs.
Acceleration (0-60 mph): 7.9 sec.
Braking Distance (60-0 mph): 132 ft.
Roadholding Index: 0.76
Base Number of Cylinders: 4
Base Engine Size: 1.8 liters
Horsepower: 150 hp @ 5700 rpm
Torque: 155 ft-lbs. @ 1750 rpm
2000 Audi A4 Sedan (front wheel drive)
Weight: 2998 lbs.
Acceleration (0-60 mph): 8.0 sec.
Braking Distance (60-0 mph): 139 ft.
Roadholding Index: 0.79
(Quattro would increase traction but add weight, cancelling out any change in 0-60)
Incedentally, I've seen better numbers for the Passat once broken in, 0-60 in 7.5-7.7 is possible. I have also seen slightly better numbers for the Audi. I think in 0-60, it's about a draw on dry pavement. Audi's advantages beyond prestige are availability of Quattro and a Sport Package with 17" wheels and stiffer suspension.
Check out www.vwvortex.com and www.audiworld.com for excellent owner forums.
TIA
Dave
2 YR. - 24,000 MILE WARANTEE? HOW OLD IS IT? INTEGRITY OF CAR MORE IMPORTANT THAN COLOR - (NO WONDER U MAY BE GETTING A "GOOD DEAL"- ON THE PRICE ONLY?? GOOD LUCK
I'm not sure if the stock 1.8T Passat is faster 0-60 then the V6 version, manual vs. manual. If it is, however, one reason mght be that VW has possibly understated the HP or torque ratings of the 1.8T. This has been bandied about before, but from what I have heard (and I could be mistaken) dynos of a stock 1.8T Passat by Garrett showed a max torque of 179#, about 30# more then advertised.
Either way, the turbo 4 feels pretty fast to me with the stick. MANY people have stated however that the 4cyl. is a bit sluggish with the auto tranny.
The only way to find out is to try them both, I did, and for me the extra grunt of the V6 wasn't worth the extra $3-4k.
BTW--I just had my 10k mile service (at 16k miles!) and the car is in great shape. Tight as a drum and no problems whatsoever. Recent sub-zero temps and snow haven't effected it one bit. The stock Mich. tires have been excellent in the adverse conditions. One thing I have noticed is how communicative the suspension, tires and brakes are in the crappy weather. Very important when thins get slippery to know what is going on under the car.
So,
Anyone with the cloth tan interior? How does it look after use? The seats are light and probably stain easily. If that is true, I will opt for the black.
Dave
My cassette player broke, and I waited for it for two months. They had it in backorder. I learned they have a lot of problems with radios.
Radios are in backorder, but they are selling a lot of new cars with new radios. So basically, they prefer to sell a new car than to satisfy a customer they already have.
Radio sucks. Too much heavy bass even when set to –9, and very low middle freq gain.
The factory warranty of 2 years 24k miles is too short indeed for current standards. I also read that the 10 years/100k miles warranty for the power train is a hidden warranty that most manufacturers will honor when properly requested. So perhaps VW only made public what has been a hidden policy in US for years.
But what is really annoying is the lack of interests the dealer have on servicing the cars.
In South Florida apparently they have too many customers. Perhaps they a selling too many cars, too fast, or the cars are having a lot of problems. I had to wait for a month for an appointment.
Esserman International VW service department sucks. It is very difficult to talk to anybody there. They won’t call you back either. They replaced my radio, but screwed-up a speaker. They did not have the parts to do the work related to recalls, even when I told them all the work the car needed. They said the repaired the mirror defroster and charged it to the factory, but they don’t work either.
but trouble ever since.
The car runs OK when it is warm. However, once
the temperature drops below freezing all hell
breaks loose.
The car refuses to start when it gets too cold.
Finally if it does start, the fuel supply just
cuts off on you once in a while. Also, the cruise
control does not work for the most part.
The car has been to the dealership 5 times now.
It is currently at the dealership.
The first time they replaced the throttle position
valve and told me that everything will be fine. I
brought it home and had the same trouble.
I took it back and this time they changed the fuel
pump relay and told me that everything would be
fixed. As usual nothing was.
The third time I took it to them, it was an
unusually warm week. They just claimed that
nothing was wrong with the car and gave it back to
me.
When I drove it to work the next day the check
engine light came on. I took it to the
dealership.
They "flashed" the computer (basically updated the
software on the computer) and told me that
everthing should be fixed.
The car would not start after I came back from a
10 day vacation. It is currently at the
dealership.
I am just fed up with all this trouble. Just
wanted to warn people that there are Passat lemons
out there.
I guess the VW people have not fixed all the
electrical problems that have plagued them in the
past, atleast not in the car I own.
Yep...every car maker has a lemon here and there, cars are made by people and people are inperfect. Sounds like you have a definate lemon, you should be pursuing the correct channels to get VW to take this car back. Every state has a lemon law for just this purpose.
Personally, over 16k miles and the car is prety much flawless. It has never failed to start right up even with the sub-zero temps here in VT lately. I couln't be happier.
Pat
HAS ANYONE EXPERIENCED THIS . ps I HAVE A SUNROOF
I've only heard of one or two people having this problem, and I've been reading Passat boards for 2 years now.
I'm assuming the seat wasn't key locked when you broke this.
--Mike
Dennis P.
See post #335 for the problems which I have had with my wife's 99GLX passat. Finally, last week VW accepted that they could not fix my car and would put me in a new car. My car (bright green) had 7900miles on it and I had owned it for 5 months (it was at the dealership for 2 of those months being repaired). Although I had paid $28000(inclusive of all taxes and fees), VW was ready to give me back only $25000. I did not want to get the cash and loose $3000, so I asked VW to negotiate with the dealership and put me in a new car with minimal loss to me. These were the options they gave me.
1. I could have the one remaining 99GLX (black color,tan interior 590miles) for $200 or
2. I can have any 2000GLX from the lot for $1800.
I went there yesterday and drove out with a new silver (black interior) 2000GLX. I also got an extended 4yr 60,000 mile warranty for $842. So, accounting for the approx. $800 price increase from the 99 to the 2000 model I ended up paying $1000 for the 7000 miles my wife drove (15c a mile).
I think VW USA is a really tough company to negotiate with and I would have never even considered buying any of their products again. However, working with the Albuquerque dealership people was great and I am happy with my new passat and IF things work out well might even consider buying another VW for myself in the future!
After having the engine diagnosed with piston slap(car had 31000km) on it and the Volkswagen Dealer in Halifax Canada said they would get me a new engine. Well after a month of waiting we found out that Volkswagen in Germany does not have an engine anywhere in the world they can get to replace this broken one. This all took place on October 4/99 in November 4/99 they came to the wife and I and said they would give us a new car(99) were as they can't get a new engine for the old one. Also there was NO MONEY Exchanged as we said we bought a new car and a new car we will have.Case Closed! The old Passat Wagon is still sitting waiting for an engine.Volkswagen does NOT make an engine that will fit a standard or Automatic they are too different engines entirely- Not interchangeable.
We have 10000kms on this one it also has the 1.8 engine and we have had no trouble yet. We have had a valve cover leak but in talking to the Machanics this is normal for them to leak until they put glue on the gaskets.
Also I see where someone had trouble with there Service Engine light coming on. We too had that problem and we tracked it to the Coil Plug going to the spark plug, what we did here was put electronic silcon lubricant on the plug connections and has up to this point in time CURRED the problem.It came up with #1 plug miss firing on the scope.
Anyway I have to say we are happy with the service we have gotten from the people at Hillcrest Volkswagen in Halifax N.S. They treated the wife and I really great and always try to look after the problems we might bring them.
We will be watching things closely to see how this one runs.
Thanks for giving me this space.
Dave
They replaced it but never could get rid of all those little noises. I always felt cars were sheet
metal on wheels to get from point A to point B
Well This 2000 Passat has change my whole way of thinking about Driving and Yes, I do take the long way home. Love this car
Assuming that everything is in it's place, are you sure it isn't just your perception? What was your last car? No flame, just curious.
My wife works with a women who has a new Passat and hates it. My wife, who loves ours, asked her what she doesn't like about it..."I can feel every little bump, it's too noisy, and the transmission shifts to hard." Her last car was a Lexus, go figure.
I don't know if you are joking or not, but it is probably true about the engine a road noise covering up the wind noise in your Civic! With my first luxo car I heard a lot of noises I never noticed before.
However, there is always the possiblilty that a door or window is not set properly and there IS some unusual wind noise! Try to see if it is coming from a particular area, at what speed, etc. Maybe drive another at your dealer to compare.
If it's still too noisy, there's always the ES - I had one, it was wonderful.
I'VE KNOWN MY MECHANIC FOR YEARS AND HE BELIEVES IN DRIVING CARS INTO THE GROUND. IS ANYONE ELSE EXPERIENCING THIS TYPE OF PROBLEM?
1) dash and radio/heater console lights work only intermittently (dealer already changed light
switch.)
2)foul smell (thought it was exhaust or oil burning) being drawn into interior by fan when heat and fan is on. Dealer says its from the metal
of the ac unit which probably has condensation build up but its the middle of winter.
Anyone else have these problems or have any suggestions?
IF YOU PUSH UP ON THE HEADLINER FROM THE INSIDE NEAR SUNVISOR OR INTERIOR LIGHTS THE NOISE IS EVIDENT.Hit a bump and the noise occurs.
Steps to fix as follows:
Remove cover to emergency sunroof closing crank see manual.take very ligh packing material( not buble packing )white styrafome type material is best.Push in between headliner and roof, use a flexable flat rod.
Open sunroof notice space between sunroof lip and roof.Push insulatin inbetween roof and headliner.
Press indide hedliner original noise sould be gone or less.Continue insulating as required.
Press the metal rim of the sunroof together .
aglllggglll....Audi A6 Turbo....glllggll.....
Pat
