Chrysler Cirrus - Check Engine Light on - Can't Find Anything Wrong
I just purchased a 1997 Cirrus with 15400 miles.
Two days later the "Check Engine Light" went on and
the dealer, when called, said "Run it up to 70 MPH
and that should kick the light off, since we just
did an oil change and checked the car out." When
this didn't help, he said "Unscrew the gas cap and
put it back on really tight." This didn't help
either. Then he said, "Well, the Chryslers
sometimes have this problem; don't worry about it."
I can't accept this answer. Driving around with
the "Check Engine" light on seems a stupid thing to
do - those lights usually have a purpose, don't
they? Any comments or suggestions for help with
this?
this?
Unless you misunderstood what the service guys said I think they are pulling your leg. On the OBDII systems there is not a single "chip" that turns on/off the "check engine light" but many parameters that take data from various sensors and compare it to data base "norms" then determines if the light should come on or not. Chryco vehicles are notorious for false codes telling the computer that a code is loaded. Many shops simply don't want to mess with these problems as they can be very time consuming and keep coming back again and again. The solution? Many times they simply remove the bulb and gee it's fixed!! I caught a dealer doing this and found it with my laptop and a diagnostic program from a friend of mine. when confronted about this the dealer said "well, they must have checked the bulb and forgot to put it back in"-- Right!! Just another sleazy SOB dealer cutting corners>
janl
ENGINE LIGHT CAME ON ONCE BECAUSE OF A LOOSE GAS CAP. IF THE CAP IS LOOSE OR MISSING, A DIAGNOSTIC PUMP USED TO DRAW A PARTIAL VACUUM TO CHECK THE FUEL TANK EMISSIONS WILL SET A TROUBLE CODE AND CAUSE THE ENGINE LIGHT TO COME ON. MY LIGHT WOULDN'T GO OUT EVEN WHEN THE LOOSE CAP WAS TIGHTENED - IT REQUIRED A RESET OF THE COMPUTER CODES WITH A SCANTOOL TO EXTINGUISH THE LIGHT.
WHY BUY A 99? ALL THAT YOU WILL REALLY SAVE IS THE EXTRA $750 ON THE REBATE.
THE 00 COSTS AN ADDITIONAL $400 ON THE STICKER OVER THE 99, BUT THIS ALSO INCLUDES THE DART ALLOY WHEELS INSTEAD OF THE STEEL WHEELS WITH CHROMED PLASTIC WHEELCOVERS (THEY LOOK REALLY TACKY) AND AN UPGRADED 8 SPEAKER RADIO WITH CD CHANGER CONTROLS - MORE THAN OFFSETS THE $400 INCREASE.
can anyone tell me if this is normal? thanks.
carlady/roving host
I just bought an LXi last weekend. I test drove the Cirrus, the Dodge Intrepid, and checked on some used luxury cars. Of them all, the Cirrus was the most luxurious, and best value for the money. I got a super deal on it, because Chrysler/Plymouth is offering .09 financing for the month of September. The Cirrus I purchased has a sunroof, 6 Cd Built in changer, leather, keyless entry, and it's a pretty car. Price on the window was $21.5. Nothing else could come close with those options at that price.
Maby the dealer will let you sit in the car and listen to the stereo while they try to fix it on your sure to be many trips to your local Chryco bone yard.
Chryco cars have been the worst I've ever had (2) NO MORE for me. No bargain at ANY price IMHO
Floridian
Chrysler Cirrus check engine light on - can't find anything wrong and can't find anything about it!!!!!!!!!
Sign me stupid, but finding info in this "Town Hall" is making me nuts.
If you find out what you need to know, please post it here so that anyone else with your problem won't be so hard-pressed to find an answer. Think of yourself as a pioneer in the field of Cirrus Check Engine Lights.
This site has info on Chrysler products.
My Plymouth Reliant has a built in fault code reader. It is activated by turning the key on-off-on-off-on within 5 seconds, a light will flash the 2 digit numbers in reguard to which fault code has been detected.
Good info on the site above, maybe it will be of some help to you.
Bob
We have a couple of duplicate topics where we
are talking about the same thing. Please go here:
to discuss all "Check Engine" light issues.
your host, Bruce
