SNOW TIRES
2
  • igloomasterigloomaster Member Posts: 249
    I have heard that "Toyo" tires are nothing more than economy tires.....
    If you buy a new base model compact car, it is highly likely that the vehicle will be outfitted with a set of Toyos.
    I know nothing about their Snow tires; I didn't realize they made them.
  • joe107joe107 Member Posts: 8
    Just bought 4-Ultra Grips and paid $62.00 ea.
    at a Kmart/Penske Auto.
    Been running on 4 new Ultra grips for about a month now (still waiting for the first snow)
    and they do handle very well on dry and wet roads.
    They are on my 99 S-10. Also.....any vehicle will handle best with the "same" tires on all 4-wheels.
    Just putting snows on the rear....you give up some handling because of the grip/flex/etc...diffs
    in the front and rear tires. A front tire, on a rear drive cars has to grip too only in a differant fashion than the drive tire.
    The Ultra Grip is rated for Mud/Snow/Rain....they are quiet and I'll leave them on all year.
    I would not recomend leaving snow tires on all year. While some snow tires may handle much better than others in wet and dry conditions (as I have pointed out in earlier posts) they will still not be near a good summer tire or all weather tire. By the way all weather is a misnomer it just means you are compromising year round.
    Your best bet is to use Winter tires in the Winter, and Summer tires in the Summer. This is especially true for trucks and SUV's which don't handle or brake as well as cars in the first place.
    You are dead on accurate about using four of the same tires. That is the best way to go.
    Thanks for the price info on these.
    I have, in the past, used Goodyear Ultra-Grips on my Honda Civic, and left them on year-round. They do fine on dry roads as well, and they didn't wear down as fast as other 'snow' tires might when subjected to the hot pavement in the summer.
    I think that the bigger part of the picture [in the belief that snow tires shouldn't be left on in the summer]is the fact that most snow models are made of compounds that will wear down quite quickly in the heat. The handling issue is not as prominent a reason. Heck, who wants to pay for tires earlier than necessary? I was just being lazy with the Honda, and left the Ultra-Grips on there all year. I surprised myself with how well they stood up.
  • markbuckmarkbuck Member Posts: 1,021
    Ran 'em on my temporary '98 Escort. Best traction I have ever experienced in the snow. Played rally racer every weekend on the backroads forest service roads!
    They are what I would buy for winter use!
    ...also...these are often overlooked, but are great studdable snow tires. I run them on my Ranger, with a size p215/75 r14. That 215/75 combo makes for a taller, thinner tire; and I have all 4 studded.
    I could drive up the side of a building with those things on!
    Studs are nice on the ice but boy! last time I ran a studded tire (many years ago) they were nasty when you're driving on the dry roads. Saw too much loss of traction and those cute little grooves they leave in the road.
    well, i must admit my days of "speedracer" are long overwith. as long as you handle the vehicle normally/calmly - you shouldn't experience a huge issue with handling. yes, they do represent a tad less rubber contact, but i kind of like those grooves in the pavement....makes me feel like i'm keeping the devil down in hell where he belongs.
    going to a larger diameter tire effects the speedometer, which in turn effects the computer (for those who have one), which in turn effects the timing, etc....(all those neat computer functions that use the speed sensor)
  • SporinSporin Member Posts: 1,066
    10 winters in Northern NH and VT and I have NEVER run dedicated snows on my FWD cars. Like brians said, th majority of my winter driving is on dry, salted roads, with only the occasional heavy snow. Ice is usually not a huge problem either. I live "in town" so the roads are plowed quickly. A good set of all seasons have been fine with me even with driving in bad weather. If the weather gets worse, I slow it down a notch, simple.
    I am NOT saying nobody needs snows, but just that IN MY CASE, it is not neccesary.
    The biggest factor of winter driving safety is NOT your tires, it is driver attentiveness and driver judgement. Slow EVERY move you make down, keep alert for icy patches and give yourself extra time to get where your going.
    During storms in my area, the first vehicles that go into a ditch are SUV's and Audi Quattros. It seems that some people think that their AWD or 4WD gives them the ability to counteract PHYSICS. If you use snow tires as that added measure of security, that is GREAT, but if you think that snows will allow you to go faster in bad weather, then you should just stay home.
    Just MY opinion, concerning MY situation. :-)
  • rs_pettyrs_petty Member Posts: 423
    Are you available to teach classes on this to the morons around the DC area?
    I do a lot of winter traveling up and down I89 in NH(north of Concord), often the majority of sane traffic is traveling at 50-60mph in bad weather. It never fails that a Explorer or other SUV goes flying by everyone up the passing lane, doing closer to 80, only to wind up in the median a few miles ahead. Overconfidence in AWD or 4WD is the culprit. Another thing to consider, the M+S tires normally found on SUV's are WORSE in light snow and ice then a standard, all season tire due to the smaller number of sipes in the tread desing. They sure do look tough at the mall though!
    Silly flatlanders.:-)
    Sporin - thanks for the input. It is true, most folks could do OK with their all season tires.
    I, on the other hand, employ both. I slow way the hell down, AND I use snow tires.
    I put the snow tires on, because as you indicated, PHYSICS plays a HUGE part in winter driving. The physical properties of a good snow/ice tire are worth it to me. They are like a warm set of winter gloves for your hands.
    Yes, you could simply stuff your bare hands in your coat and do just fine. I like the gloves.
    igloomaster,
    I strongly agree, if you have the means, and you feel conditions warrant it, snow tires are a great extra measure for safety.
  • travelertraveler Member Posts: 67
    My first visit to the snow tires conference and sporin hit the nail on the head about SOME of the drivers of SUV and other AWD vehicles. They are the ones who get in the ditch or cause an accident because they think AWD means you can drive just as fast on snow as dry pavement.
    My self I use snow tires instead of all seasons just for the fact of the few times that I need the extra traction.
    adkim
    narrower tire = smaller contact patch = better grip. go for a narrower tire. myself, i was able to keep the SAME tire HEIGHT, with a decrease in tire WIDTH. that's worked great, and i would recommend that.
    also, i am a big advocate of studs, all 4 snows.
    best-
    igloo
    I don't think the narrowest tire may necessarily be the best. While traction is important, also consider ride quality, load ratings, etc...Your decision should be to optimize the characteristics you feel most important and minimize any negative aspects. The 195/65 sounds better to me than the 165/80. Don't forget that winter weather also creates rough road surfaces. Your tire must be capable throughout a wide variance of conditions. I believe the rubber compound and tread pattern of modern snow tires overcome the old trend of narrower is better.
    i agree with you. i should've been more specific. i think that narrower is better within the parameters that rs described above.....
    if you go narrower than recommended you may encounter different problems.
  • scoobidexscoobidex Member Posts: 1
    I'd like to put winter tires on my 99 dodge intrepid, and I'd prefer to have them installed at the dealer. The only brand available at the dealer is Mopar; but the dealer says they're made by Michelin. Does anyone know if this is true? and if they're actually equivalent to the name brand Michelin tires?
    I've found that tire dealers will say that their house brand is ALWAYS made by a major brand; problem is, they usually can never prove it. Go to www.tirerack.com and check their prices on a wheel/tire package. I bought a package for the wife's Three Series and even with shipping the cost was less than $100 more than what the local shops wanted for just the tires(Michelin XM+S Alpins). It took me a little over one hour to make the changeover in my garage, and best of all I won't have to pay to have my summer tires remounted next spring. In any event, make sure whatever you buy has the "snowflake on the mountain" symbol which ensures that the tire meets the new severe snow traction standards. Good luck!
  • richvonrichvon Member Posts: 2
    Is there a compelling reason to buy wheels to go along with the snow tires I plan to purchase? National Tire and Battery is offering lifetime mounting and unmounting of their winter tires for $40. Has anyone had bad experiences (damaged tires) from the process of mounting and unmounting tires on the same set of wheels? Separate wheels would probably run me another $300 plus new valve stems and lug nuts.
    Oh, I think I'm going to buy Michelin Arctic Alpins. I've had good experience with Michelins.
    Rich
    The only reason I could see, if you can get this deal, is to save your original wheels the ravages of winter. There should be no damage to your wheels if the mounting/balancing job is done right.
  • guitarzanguitarzan Member Posts: 873
    If you have nice alloy wheels, a cheap steel wheel would be good for wintertime. The extra weight might even help out.
    A narrower winter tire is good for one reason that I know of: It cuts through slush and snow easiest. Wider tires do more lateral sliding under such conditions.
    Guitarzan
    Community Leader/Vans Conference
    Using steel wheels for the snows keeps my alloys away from winters worst. I went ahead and sprung for OEM hubcaps and the effect is quite pleasing. The cost for the wheels and covers came to @$150.00. Tire Rack mounts and balances free when you purchase a tire/wheel package. I perform the changeover myself and thus save a few bucks as well. A good tire shop won't harm your wheels dismounting/mounting tires, but there are darn few good shops around. If you have the workspace and a good jack, I'd advise having a set of mounted snows- and doing the changeover yourself. It's only takes two hours a year.
  • boo20boo20 Member Posts: 85
    How do you torque the wheels to factory spec?
    I have a 1/2" drive Craftsman torque wrench(I know, it's no Snap-On :( )with a six-point socket. I recheck the lug bolts after @600 miles and then forget about them until spring. Of course, I check the tire pressures every week.
    once again, I must praise the virtues of having 4 studded snow tires on my Ford Ranger.
    rear-wheel drive, sandbags in the bed for weight, and studded snows..... it's the best way to go.
    i saw volvos and mitsubishi's crashing this morning on the way to work during the blizzard we are getting here in new england.
    i was fine.
    studdies are the way to go.
  • hiflyerhiflyer Member Posts: 79
    About a month ago, I had four Michelin Artic Alpins mounted on my '99 Passat. Since then, I've been quite satisfied by its handling characteristics on both dry and snowy roads.
    On dry roads, the Alpins seem to handle as well as my stock Conti Contacts. There also appears to be no discernible difference in noise level or ride. The Alpins do seem to weave a little more during straightline acceleration, but strangely feel better in the turns. Now some of this may be due to the fact that the Contis are not the most performance-oriented all-seasons as well as the 20k miles I've already racked up on my set.
    During a couple snow storms we had in MA lately, the Alpins provided excellent traction especially on the highway. The only real problem occurred when driving along a snow packed side street. The back end of the car constantly felt like it wanted to swing out. I countered this tendency by steering against it and keeping my speed at a low and constant rate. Even then, I didn't seem to have as much trouble as most of the other motorists.
    I can't say how well they compare to other studless snow tires such as Blizzaks. However, the Alpins would possibly last longer given their harder rubber compound while still providing good safe handling regardless of conditions.
  • pcleveland2pcleveland2 Member Posts: 516
    Am running Artic Alpins all around on 95 Nissan Sentra. The Artic Alpins are great in heavy snow, on ice and on bare road. Best tire I've ever ran. Can really maintain highway speed in adverse driving conditions. Live in upstate New York south of Buffalo (Lake Erie Lake Effect Snow - Blizzard Conditions at times). Glad I read the Consumer Reports Article. Michelin has their act together.
    Previously had Blizzaks (just on front). The vehicle with Blizzaks when slowing going into a curve always wanted to go backwards. They didn't like slushly snow when passing on a four lane. Was afraid of being sucked off the road.
    Agree wholeheartedly with the performance of 4 studded snows.
    My 4wd silverado performs almost like dry weather in ice and snow.
    Also not much decrease in performance when dry, pulled my 5,000 lb travel trailer 400 miles last weekend at 75 on dry interstate roads.
    Headed to Yellowstone for week long snowmobile tour, likely will not have to chain up with my 4 studded snows.
    your experience with alpins is common - you get mostly good and some bad too.
    while studded snows may not help the sporty performance, they certainly would help you on those snow-packed side streets.
    read markbuck's last post!
  • ccotenjccotenj Member Posts: 610
    i'm actually getting pretty decent stickiness with the studless blizzak mz-02's. don't know if we can even use studdies here in new jersey, they really beat heck out of the road.
    -Chris
    they are legal in Mass from November 1 to May 1.
    check with an authorized dealer; they'll know the law. they're not as bad on the pavement as people think; it's only the losers who feel the need to spin out their back tires and shoot sparks everywhere that dig up the pavement.
  • microrepairmicrorepair Member Posts: 508
    Some posts back in December talked about who leaves the road first in snow conditions. A year ago, on the way into work one morning during a light snow fall, the ONLY vehicle I saw in trouble on my 22 mile trip, was a 4x4 Explorer where the grille was carrying on a conversation with a rather large tree. The vehicle was at right angles to the road with the rear hanging in to the road by a foot or two. The vehicle was on top of a low stone wall, 12-18" high. This section of road was straight and had only a very slight grade to it.
    As others had suggested, drivers cause accidents, not the vehicles. Driving on snow requires an attitude adjustment and a willingness to "slow down all your actions", as someone else had suggested. Having the right tires for the condition helps a lot, but they can't make the reduced traction problem disappear.
    P.S.: I'm in eastern Mass. and although we don't get as much snow as Buffalo, we get a lot of sloppy road conditions requiring that your brain be in gear when your transmission is.
    i agree. driver's must change their attitudes, put down the freakin' cell phones, and slow down.
    my experience has been that even with myself being much more careful, the success of the equation is exponetially greater when i equip the vehicle with studded snow tires that are designed to grip better than conventional tires in hazardous conditions like snow and ice.
    put an idiot behind the wheel with the proper tires, and you have an accident waiting to happen.
    put a careful person behind the wheel with the wrong tires, and you still might have an accident.
    i speak from experience: i live in Mass as well. a couple of years ago we were getting belted with enormous amounts of snow every other day (seemed like that). i was driving slowly on the highway, and my car decided to spin out and to a 360 into the jersey barrier. my tires couldn't handle the slick icy surface, even at slow and controlled speeds.
    if i had studded snows on there, that would not have happened. ever since i outfitted my vehicle with the proper tires, (in conjunction with care) i have been trouble free.
    Best!
    reading thru the posts noticed some comments that reveal that some people think the high traction snows with studs on snow is almost equal to dry road driving. When they are in an accident driving as though on dry road and siiting in the ditch, median or other (hopefully still alive)wondering " duh what happened" think on this you were driving on snow and ice and no snow tire will give you the same handling and traction of a good tire on a dry road.
  • rdeschenerdeschene Member Posts: 331
    I have a '93 Corsica, and have 185/75R14 Michelin Arctic Alpins on all 4 wheels. We've had a fair bit of snow, and some ice, these last couple of weeks and these tires have been excellent.
    They're also quite stable and quiet on dry road surfaces. If you want to have predictable and equal (as close as possible) traction at the front and the rear, I would go for 4 identical, snow tires not just 2. Too often I have seen vehicles fish-tail or "plow", and they did indeed have unequal tires front vs. rear.
    Have you actually driven a 4wd vehicle with four studded snow tires on ice and snow?
    While not as good as running dry, it is phenominally better on ice....
    Before last winter, I bought four snows for my car and the tire dealer recommended the Nokia or Gislaved tires, both from Sweden. Yes, Nokia is the cell-phone company, a rather large conglomerate in Europe. Anyway, the dealer said that although tires like the Blizzard would give slightly better traction on ice, the Nokia and Gislaved would outlast them about 3 to 1. He says he has seen Blizzards wear out in 10,000 miles whereas the Nokia/Gislaved tires routinely last 30-40K miles. And they are about the same in price. Of the two Swedish tires he recommended the Nokia as having slightly better snow traction.
    Well, I bought them and am very happy with them. They do provide excellent traction on snow. They are a little noisy, but hey, aren't they all, if they're any good? I also have not noticed any serious degradation in steering reponse or handling on dry roads compared to the all-season Goodyear Eagles I run in warm weather. And they seem to be wearing very well so far, about 10K miles..
  • davechendavechen Member Posts: 41
    Flame me if I'm being too off-topic, but a number of people do not seem to live in climates that really require snow tires more than 10% of the wintertime, or at all. I live in the SF Bay Area, where we get snow once every ten years (though the hills get a dusting once a year). I drive up to snow country 2 or 3 times per winter.
    Does anybody have those octopus-like gizmos that latch onto a connector that is pre-mounted on the wheel hubs, and have 8 or 12 arms that grab onto the tread surface? The arms have pads of studs built into them. Install/removal looks like it would take 30 seconds per wheel.
    These seem to be a good alternative for those of us light snow-country travellers. Kinda pricey ($300 or so!), but convenient.
    Thoughts?
    Dave
    According to my research (not a sales pitch) the Ultra Grip was not made as a snow tire only. The tread design/tread compounds give it snow worthiness. The tread was made more aggressive than a standard dry/wet road tire to benefit those
    who experience seasonal changes or do some 'minor'
    off road driving. Off Road is mainly meant for those times you may encounter some dirt/slag roads
    not some heavy 'mudding" I guess we'll see. As I said, so far they work very well on the dry roads and the wet roads.
    Yes I have driven a 4wd vehicle with studs in the winter. It did indeed accelerate quicker than a 2wd. I guess I didn't make myself clear but some 4wd drivers think they can still go the speed limit or faster in deep snow and/or hardpacked snow which is still not the case, you are not going to stop or steer that much better than the other guys vehicle in an emergency.
  • garthgarth Member Posts: 66
    the greater weight (read: inertia) of a typical 4wd means it's actually *harder* to stop on a slippery surface - the moral of the story is drive slowly, no matter what you're driving.
    Have to disagree with your last post. More weight means more normal force on the tires which increases the stopping power linearly with normal force......
    Only thing I think you lose with 4wd is greater unsprung weight of the front end.
    Yup, gotta slow down on ice no matter what, but studdies will add performance in extreme conditions in both starting, stopping and turning.
    But, I live at 7,000 ft in the mountains out west where driving conditions are extreme. Agree with most that common sense in moderate climates will get you through the occasional snowstorm.
    Use Z-chains occassionally for quick chain up when required. Can put them on without moving truck. About 5 minutes per side if you are practiced up. SCC corp. Great product.
    The V-Bar reinforced chains that I also carry when really boondocking are about 20 minutes per side. Can push snow deeper than fron hood when these are on a PU with a bed full of ballast.
    i believe that's how i've had success in my RWD Ford Ranger
    i put 4 80-pound sandbags directly over the rear axle, and i use 4 studded snow tires that are narrower than my summer tires. the combination of weight, a narrow contact patch, and studs works VERY, very well.
    during a storm, i choose the Ranger over my FWD Honda civic.
    yeah, that's why 18-wheelers stop on a dime when it snows.
    you DO have an increased normal force with greater weight, but you DO also have increased inertia. i can't see how stopping a heavy moving object, especially on a slippery surface, is easier than stopping a light moving object...
    another point: light trucks/SUVs tend to have very poor brakes when compared to cars (look at published figures for 60-0mph stopping distances...)
    18 wheelers don't stop worth a damn even on perfectly dry pavement.
    It's all in the tires. Put a set of sticky tires on my Silverado, and it will stop with the best of 'em. Of course, my silverado has 4 wheel disc brakes.
    put the same type of sticky tires on a camry... now which one stops quicker? your silverado?
    can't break the laws of physics, even if you think your tires stick to snow and ice...
