Other possible tire sizes available to fit 2008 Ford Escape XLT V6 rims.
senseireysenseirey Member Posts: 1
edited June 2016 in Ford
What other possible tire sizes are able to fit on the Ford Escape XLT V6 rims other than the factory 235 75 16? Would a 255 55 16 fit on the XLT rims? What about 18 inch rims? What sizes would you recommend?
  • texasestexases Member Posts: 11,205
    I'd go to tirerack.com and see what tire size options they list for your Escape.
    Do they even make a 255 55 16? If they do, that won't work for you.
    If you meant 255 55 17, then no, that size switch isn't recommended.
    If you wanted to go to 255 60 17, that would work.
    Or 255 65 16 would work.
