Why does my 2000 4.7L Dodge Dakota not start?
We have a 2000 Dodge Dakota 4.7L. The truck cranks but does not start. The fuel pump is new, the injectors are new, and the spark plugs are new. It has good fuel pressure, good spark, and good relays. It gets going with some starter fluid but dies within a second or two. At first we suspected the fuel pump and it was horrible, broken filter, but ultimately, did not resolve the problem. The spark plugs were changed, but still nothing. The injectors were all replaced, but still nothing. All relays and fuses have been tested. ASD relay was replaced and still nothing. Good spark is achieved and good pressure is achieved. What could possibly be wrong with this Dakota?
Best Answer
animeister
Member Posts: 6
Hey everyone. I know it's been a while, but I wanted to post this for the record. I found what was wrong with it, or rather, we know what the problem was and fixed it. Not quite sure how it happened though. We completely replaced the gas with new gas. After that, it ran perfectly. Previously, we had removed the gas and replaced it after cleaning out the tank of any debris. The gas looked perfectly fine. Regardless, new gas did the trick. Perhaps there was some other liquid mixed in, perhaps water. We just don't know, but whatever it was kept it from running. I have only heard of one other with similar symptoms, but he definitely had water (ice) in the tank and lived in Alaska. I hope this helps others and thanks for all the feedback.5
Answers
http://troubleshootmyvehicle.com/chrysler/4.7L/how-to-test-a-bad-fuel-injector-1
The scope allows you to measure the supply voltage to the injectors, as well as the computers ability to get the ground command close to 0v. If there is a poor connection, or corrosion in the circuit there will be a voltage drop occurring when the injectors are turned on. The moment they are turned back off and there is no current flowing, the voltage levels return to normal. A voltmeter cannot show you this since because it doesn't update fast enough.
The low amps current probe will sense the current flowing in the circuit and output a voltage that the scope can display. The resulting waveform is so precise that we can see the pintle in the injector mechanically open in the ramp as the current in the circuit builds.
Reading back through to double check, I did not see where you tested the fuel to see if it is good or not.
Starting fluid can trick you--it's so combustible that even the feeblest spark or marginal compression will ignite it.
