Low beams , not working.
                    I have a Maserati 2002  4200GT Coupe
Both low beam headlights stopped working
Low beam relay ok
Both low beam fuses ok
If bypass fuses low beams work.
All fuses on the passenger side boxes are ok.
Is there an other relay somewhere ?
Sometime had to flip the headlight switch several time to get it working,
but does not come on anymore.
I do not have the wiring diagram to test it.
Any suggestions?
I am 3 hours away from the nearest dealer.
Low beam relay ok
Any suggestions?
Answers
