driving in the winter
I know that the new Miata has "winter" tires, but exactly what does this mean? Is there a temperature below which the car should not be driven? Why? I wouldn't drive the car on snow or ice because I know that traction would be a safety issue, but what's the problem driving it on a clear, sunny, cold winter day?
So All Season tires don't do anything really well, but they can adequately cover all bases in a pinch.
So yeah, on a dry day in winter, All Season tires are fine as long as you aren't trying to drive 9/10ths.
Summer tires can add a lot of handling competence to a car but they aren't a compromise tire. They are dedicated for one purpose--to grip the road in warm weather. They also wear quickly, so using them all year (even if you can get away with it) will drive your maintenance costs up. I could see summer tires wearing out normally in 12,000 miles, so if you used them all year, that's a new set of tires every 12 months or so.
More or less all share a common feature of being useless in snow and bad in cold weather. How cold is cold depends on the particular tire, but 40 degrees is a common cut-off. The rubber compound used in summer tires tends to turn into a brick when it gets cold. Then you start sliding around and the car will handle very poorly. Some even void your tire warranty and warn of cracking if driven below minimum temperature.
If you're going to drive a Miata in snow you'll want winter tires. Larger rear drive cars like the '98 Lincoln I had do ok in snow with all-seasons, but a Miata is light and has wide tires relative to the weight of the car. Wide tires are not good for snow grip. If it's a second car and you just want to be able to drive it in cold weather all-season will suffice, though if you want to use summer tires for the fun part of the year I would get performance winter tires instead.
