mitsubishi acting funny still
So on the Mitsubishi 02 Galant Its been acting up so I go get the codes read comes, back for cam position sensor so I get a new sensor put it in and the runs realley rough stumbling all the way and cuts off I try a couple more times same thing why would a new part make it run like that I also contacted the part store they exchanged for still another new part I put it in SAME THING runs really rough stumbles cuts off. so I put the old sensor back in and starts up runs but when I put it in gear it starts missing really bad take it out of gear and it idols fine over 1000 rpm until it warms up a bit then under that it cuts off what gives
Are you sure you have an impulse to the injector from the PCM?
