2005 Ford Escape 3 windows don't work
EyeNeedHelpEyeNeedHelp Member Posts: 1
edited October 2016 in Ford
So my drivers side window and the sunroof work perfectly fine. The three passenger windows do not work.
Would this be a fuse issue? Does anyone know how to fix this?
Answers
    I would pop out the driver's master switch and test each function on that switch first. Fuses usually work all 4 windows or pairs of 2, so not likely.
    If master switch is outputting to all windows, then I think next place I'd look is the rubber enclosed "tube" between the driver's door and the body of the car where the window switch wires enter the main harness. Sometimes the constant opening and closing of the door will abraid those wires.
  • bdymentbdyment Member Posts: 573
    Make sure the window lock out button has not been accidently pressed.
    Yes, good suggestion, bdyment. I always presume people have checked that first, but sometimes it slips people's minds!
