Visitor Agreement.
I would IGNORE the catalytic converter rattling. It will eventually go away. There is NO WAY the muffler could be affected by the catalyst starting to desinagrate. (holes thru muffler are much larger than any pieces that may come off cat)
If your exhaust system is otherwise intact, I would LIVE with the rattling of the cat.... any other options would be costly and would gain very little. (but your wallet would be lighter)
... I am just trying to save you some $$ unless you absolutely have to buy new cat.
or...
Should I just continue on with the rattling noise, drive with a slight loss of power and lose $80 for the diagnostic fee?
I would imagine any catalytic converter would make a rattling noise when the emmissions are being affected. Any insight?
BTW - I just did a quick search on the internet and your catalytic converter can be had for about $500 plus you get a core charge. (paied to return the old one) Perhaps you would like to call around to some other muffler shops and ask what they would get to replace the cat.
Again, I am not sure if the problem on your 2006 would be the same thing. (I would like to think that VW has re-designed the problematic switch by now.)
Also you will hear a clicking noise after you start the car but odds are thats the electric air pump to warm the exhaust system and get it up to temp faster. That is normal..
Also with a 2.5 you will hear a loud engine, exhaust sound when you first start it cold.. It will go away if you put it in gear.. That is the start up program in the computer to help warm the exhaust system faster.. That is also normal..
These engines are do make some noises during startup and warm up.. Nothing to worry about..
Snowdance
Yes it is normal. But, at least according to the owners manual, it is caused by hydraulic valve lifters. Also, doesn't the manual say to wait for that sound to go away before putting it in gear and driving?
BTW: I was aware that the "Federal emmissions warantee" for 1999-2001 is 10years/100,000 miles.... where did you get the info that the feds have changed that to 120K miles for only the VW Jetta? I would be interested in reviewing that information.
Have you read the "Federal emmissions warantee" booklet that came with your car? (should be in your glovebox with owners manual)
http://www.epa.gov/otaq/cert/recall/vw2.htm
You may want to print that webpage out and show to dealership when you take your car in... just incase they claim no knowledge of it.
Are you using VagCom? If not... what are using to "communicate" with the ECU?
needless to say,it was not a very pleasant experience to deal with these moron mazda mechanics who were unable to solve the mystery of where the gas fumes were comeing from.i should have never even brought the car in for the recall.
This is NOT normal. If your car is still under warranty (manufacturer's or extended), insist that VW replaces the transmission. After my trasnmission was replaced, I was left with a "bad taste in my mouth" and I sold it.
I'm looking for a second car, my old corolla had an untimely demise in an accident =( But now I'm looking into what car to buy, and I love the look and specs of the 2002 Jetta, the gls 1.8t to be precise. I have a couple of questions though
do I REALLY need to put premium gas into the car, or will it suffice w/ regular if I buy it at 80k miles?
If i want a car that I can reasonably assume won't cost me over $1500 a year to maintain, does the jetta fit?
Thanks in advance for any comments, I appreciate all bits of advice (large, small...one word...)
Do not forget that the 1.8T Audi engine also requires synthetic oil.
Do you consider the cost of fuel a "maintenance" cost? (I am just wondering if your cost-point of $1500/year includes the cost of fuel)
Personally, I have the TDI engine which regularly gets over 45 MPG. (over 650 miles per tank) With the 10,000 mile oil-change-interval, my annual costs are well below your $1500/year (and that INCLUDES the cost of fuel!)
I would think if you "run the numbers" for the 1.8T engine... it would come out costing more than what I pay since it gets HALF the MPG that my TDI engine gets. (and requires TWICE the number of oil-changes)
Since you like the looks of the Mark IV Jetta, perhaps you would be better off with the 2.0L engine. It does not require the additional maintainance costs that the 1.8T engine does. (Both of my daughters have the 2.0L engine in their VWs)
If you registerd your 2002 Jetta with Volkswagen and kept them informed about your current address...then they are under Federal regulations to alert you.
Here are 2 websites that maintain a database of all "recalls" and "TSBs" (Technical Service Bullitens)
http://www.nhtsa.dot.gov/
http://www.alldata.com/
I assume you realize that a "recall" is defined as being a safety-related item that is manditory to be fixed. While a "TSB" is a NON-safety-related item that is not manditory.... but the dealership may fix for free if you bring it to their attention.
BTW: My daughter with a 2001 New Beetle got her brake-switch recall letter 2 weeks ago.
Only the drivetrain (5 yr/60K) and rust (12 yr) are covered longer than 4/50K.
I did a quick search and found the following:
" I phoned the toll free number for VWoC: 1-800-822-8987. Found out there was a 7 yr warranty to replace the broken clips free of charge."
If you want to do it yourself.... check this out
http://forums.vwvortex.com/zerothread?id=1015107
BTW... Never ever try to put the window down in freezing weather. If it is "frozen shut", you can break that plastic clip.
As for your problems with the radio... what kind of problems are you having? Please provide more details.
(Is it a Blinking red light on radio?)
There was a TSB (Technical Service Bulletin) pertaining to the radio that covered the 2002 models. Since I did the research for your window regulator - will let you do the research on that one. (HINT: The fix may be very simple one that you can do at home.... it took me about 2 minutes to find this radio "fix")
NOTE: If you do the home "fix" there is likelyhood that problem will come back. A dealership needs to 'see' the radio in the broken state for the TSB to be enforced.
Also, I ended up replacing her battery and don't know if something could've happened when I did that either.
If anyone has any info it would be greatly appreciated. Thanks for your help.
It is also possible that the GUAGE is inaccurate. There is a "coolant temparture sensor" on the engine that feeds the guage. This sensor may be the culprit.
In the order of least cost to higher cost....I would suggest that you;
1) Have the "coolant temparture sensor" replaced
2) Have the thermostat replaced. Make certain that only VW approved antifreeze is used to replenish any that is lost during that procedure.
If so, then the radio is in what is called "safe mode". The owners manual contaions the instructions (and the special key-code) to get it out of safe mode.
There is a possibility that reversing the polarity has damaged the radio. If so, then consider yourself lucky that is all that happened. There may be latent damage to the onboard computer that may not show up for awhile... lets hope that is not the case.
RESPONSES APPRECIATED! THANKS.
How in the world can you lock the doors from the INSIDE -- but there is noone inside to unlock the doors?
Are you suggesting that you cannot unlock the drivers door nor the trunk with the key in the keyhole? Have you tried all 3 keys that came with the car?
NOTE: We bought our Jetta from a used-car dealership. It came only with one key that was a combination of both manual-key and automatic entry. Therefore we went to a VW dealership to get a regular copy of the original key, fearing we would lose the original. The second key was the only key we had with us at the time.
Thx
"Lee"
I suggest you go to a repuatible autoparts dealer... they often will "pull the code" for free.
Also, it would help if you can tell us what year your car is.
