would you buy a Dashboard Cover for you new car
I am a rookie for car,buy a new car several days ago .there some Doubts .
Dashboard was so hot from the sunlight,and I want to buy a dashboard cover .
would you buy a Dashboard Cover for you new car,heat insulation,heat and UV resistant. if you do,where are you buy ?pls
Best Answers
Mr_Shiftright Member Posts: 64,481
Depends on your climate, as jason says. Where I am, not really necessarily, and I find them rather ugly. Some people also like them for cutting down reflected glare, which can be a problem in certain cars.
5 -
stever Guest Posts: 52,454
I don't use one here in the high desert but my car is mostly parked in my garage. I have a windshield screen that I use a lot when running errands and that blocks most of the sun from hitting the dash.5 -
texases Member Posts: 11,161
I use a windshield screen when parked, too. That has the added benefit of keeping the interior a little bit cooler.6
Answers
loos like comfortable.
