Low Tires Alert
It is starting to get chilly here and I know the Mini often registers a false low tire signal when this happens. However, after I re-set the gauge the first time this happened, the low tire warning came back on, this time showing that all 4 tires were low. And then the indicator showing that my back door was open came on. I re-shut the door and the indicator still came on once or twice, then disappeared. Then the tire warning went from showing all 4 tires being low to just one, but a different one than initially.
Is this an indication that I am having an electrical problem and if so, what should I do?
Answers
