2002 mitsubishi galant 2.4 4cyl
I've been trying to diagnose a cylinder2 misfire have tried all I can think of swithced plugs coil packs checked for compression and spark even checked for vacuum leaks still runnng rough I did notice that after it warms up if i keep the rpm's over 1000 to 1500 rpms it runs much better no misfire good acceleration but I let it idle no gas misses wants to stall slow take off, could it be some sort of sensor MAF, IAC or something??
Best Answer
Mr_Shiftright
Member Posts: 64,481
You might try a cylinder balance test to make sure you are dealing with the right cylinder. If that test confirms #2, then next thing I'd do is check the injector for that cylinder.5
Answers
