Any help or suggestions is appreciated.
I've had a few nuisances with the truck over these few years.
In the last couple months, it started having some RPMs drop mainly when idling but occasionally when driving too.
About a month ago, I got a check engine light.
Truck is a little over 5 years old and about 83500 miles.
When I purchased it, I also included an extended Warranty with Ethos for 6 years and 90000 miles.
We moved to Minnesota about 3 years ago so I took it to a GMC dealer close to our new home (McCarthy Auto World in [non-permissible content removed] Rapids, MN) on January 4th. They said they would not be able to start working until the 15th.
I rented a small sedan for two weeks ($300 from the 4th till the 18th).
Dealer said that the Timing Chain was faulty and that they would replace it for $2500.
Since I have the extended warranty, they call them and they agreed to pay. So far, I would only have to pay a $50 deductible.
On the 17th, they called me and told me that the chain had been replaced but when they took the car out for a test drive, they saw new codes stating that there was some debris in bank 1.
They asked me for permission to open the engine at a cost of $625 and that they would have to call the warranty again to understand if this new issue would be covered. They said the $625 would be part of the total cost if the warranty did not cover this new fix.
I had to rent the sedan again, for 1 more week ($170).
They called me a couple days later stating that the engine had sludge and that the warranty wanted to send an adjustor.
It took about 4 more days for the adjustor to come.
The warranty wants me to prove all oil changes because they state that the sludge could only be formed if I did not change the oil for long periods of time.
I told the warranty that it would be difficult to come up with all oil changes because of my move from TX to MN and because I do not do the oil change every time at the same place.
I ran around and found most of the recent oil changes from a few places (NTB, Valvoline, Walmart).
I sent the oil changes I have together with a detailed explanation of the timeline.
I had to rent the sedan again ($160).
Warranty was not responding quick enough so I told the dealership to fix the issue and put the engine back together. They told me the cost would be reduced from $2409 to $1580.
The dealership called me today again saying that the did put the engine back together but that it stopped working during the test drive and had to be towed.
They said that the best approach at this time would be to replace the engine and that if the warranty did not cover it, I would be responsible for that.
I do not know what other ways GMC is going to find to pick pocket me.
I did not only do the oil changes but also presented proof so it is not possible that the sludge happened because of oil changes.
There is something else wrong with the engine and reading through most posts of this forum, it seems the engine is bad.
I need to speak with someone at GMC that is willing to make things good for me.
This is outrageous.
Do I need to hire a lawyer for GM to put their act together?
https://www.edmunds.com/car-care/do-i-have-to-use-the-manufacturers-oil.html
https://www.edmunds.com/car-news/tips-advice/stop-changing-your-oil.html At this point they owe you an engine or the money back for the other repairs. The tech is now working on it for free anyway and will likely be blamed for the whole scenario. I can't say that GMC is directly to blame, but like all of the manufacturers they have played a role in making sure that the cars were serviced correctly and that talented technicians were doing the work. Just like Walmart played a role in making sure you had a talented technician available to you when the car broke down. The pennies that you saved back then have turned into some pretty big dollars today. It's not the engine, it's the way it was serviced. There are a lot of people who share in the blame and none of them work in a service bay.
The other day, I was pulling out of the park after a nice day with the family and the engine just stalled, no check engine lights, etc. Had it towed to the GMC dealer and a day later, they tell me the engine is seized, need a new engine which will cost $10k. They did not determine the cause of the failure, telling me it will cost extra to determine this, and don't recommend this option.
This news was obviously a tough pill to swallow seeing as it only has a little over 100k miles on the engine and was expecting to drive it for several more years without an auto payment! To get the news that it's completely dead was shocking! I've always been willing to "deal with the headaches" that this truck has given me, which, have been numerous from the water pump and power steering pumps failing early on, the AC needing repair and multiple other flaws.
I've always read through the online forums through the years and have seen this truck has had a lot of problems, including the engine. But when I asked GMC regarding whether any of those problems could have caused this catastrophic failure, they had no answer.
Does anyone have a similar experience with a failed engine with fairly low mileage?
I'm obviously not going to pay $10k to replace the engine on this truck, but what are my options now? Fight GM to get it fixed (probably a losing battle)? Try and trade it in for peanuts and move on?
If you trust the mechanics' diagnosis, then given the age of the vehicle, it seems like you should just cut your losses and move on.
$4,300 is pretty cheap for a 2007 Acadia--almost half the normal price, so I'm wondering what condition it was in to begin with.
dealership The last repairing dealership contacted the dealership who installed the motor and was treated rudely as I was , They were informed of the mistakes that were made but simply didn't care., I live in a different state and I feel that the dealer wanted to make a quick buck, did a subpar repair, and couldn't care less about there reputation or how badly it reflects on G.M.C. Any novice knows that what came out of the car has to go back in
if a part needs a new gasket please put one in, even with the contribution of 3,000 from G.M.C Im still out around
around 8.000 dollars and now an additional 600 dollars to fix an oil leak caused by a six dollar gasket that was reused when motor was installed in the car. When a motor is swapped the new remanufactured motor comes without all the pieces attached , brackets, manifolds , and the parts are supposed to be inspected, gaskets replaced
and the parts re installed correctly this was not done, and verified by another dealer This is really disturbing in two ways what was the level of competency of the tech that worked on the car, and what are the core values of G.M.C and or the Dealer in Ft. Stockton Texas who thinks this is the way to treat customers. As a Side note flying to Texas to pick up the vehicle and drive it back to California, I sat next to a very nice person who happened to be an executive for Toyota,( She gently teased me for buying a G.M. product ) who was going to Texas with the purpose of expanding their business there,. If G.M.C keeps treating their customers like this Toyota wont have a hard time, expanding their business. There was a case opened # 9-5075352781
everything said in this article is documented by receipts and photos , I am thinking about starting a video blog on you tube , containing the good and bad, it will be painfully truthful about the experience I have had, and may be of benefit to someone out there deciding which new vehicle to buy, or where to get your car serviced
feel free to post an email on this site and I will send you all the photos and particulars, so Mr.or Mrs consumer can decide for themselves. In the meantime I hope nothing else breaks on this car
