08 EX-L - Droning/Humming noise around 2k RPM
                    Like most people have described with these vans, mine (or should I say, my wife's) is making a pretty loud drone/humming noise between 2-2.5k rpms.  As others have described before, its almost like a ram air intake sound.  This van is sitting just under 139k, we've had it for 3 years next month and have had no other issues out of it.
Here is how mine is different from others that I have read about on here. It only happens in gear, moving or not. If I'm going down the road and its happening, I can pop it into N and it goes away completely. This is making me think it isn't the wheel bearing issue that others have had with the same sound, and something on the tranny/torque converter end.
Also, it seems to almost go away after the car is warmed up, not 100%, but I'd say 90%. It doesn't really sound like a heat shield wiggling around either. I will try to make a video of it tonight if that will help, but like other videos posted of the issue, it seems hard to pick up the sound.
I'm planning on spending some time on it Saturday, so I'm trying to get plan together on where to start and what to be looking for. Any help will be greatly appreciated.
Does it increase or decrease in frequency as you increase or decrease speed?
The frequency does not change with speed, but it goes away as soon as you hit about 3k rpm
Tire balance issues wouldn't improve as the vehicle warms up.
Wheel bearing noise would increase and decrease with speed
I'll get the van up off the ground this weekend and check all the connections from the exhaust manifold back.
I saw a comment on another thread about a flexible connection between 2 of the pieces are the Cat being the issue, hopefully mine ends up being similar.
I checked all the exhaust mounts and connections and they seemed fine to me. I also took a look at the motor mounts and as far as I can tell they also look fine. With one exception, the front one caught my eye. It kind of looks like it is compressed, which is on the driver side of the mount. This might be normal, but it looked out of place to me.
I checked in a weekend or two ago and don't remember seeing any noticeable breaks, but I guess there could have been a hole or tear that wasn't visible.
Looking to see if there is a way I can pull it back together and weld it back together, but if not it looks like I can get the A pipe for about $100.
Cheers
