Tips for Vacuum Extraction of Engine Oil Please
[Deleted User][Deleted User] Posts: 0
edited December 2016 in Subaru
I used my spiffy 7 liter vacuum extractor to change the oil in my '17 Forester Turbo but managed only to get 4.5 rather than 5.5 liters of oil out, despite a lot of poking around of the "straw" hose down the dipstick tube. Was this a lost cause, and must I really put the car on ramps and remove the drain plug to drain all the oil? Or maybe one of you knows what just-right angle to orient the car in? Up/down/tilt right or left??
  • thecardoc3thecardoc3 Member Posts: 5,876
    The engine wasn't designed to be serviced that way. You need to pull the drain plug to drain the old oil correctly and don't forget to replace the sealing washer and torque it.
  • dcm61dcm61 Member Posts: 1,567
    Get a Fumoto Drain Valve. Makes oil changing quick, with minimal mess.
    https://www.amazon.com/gp/product/B003VCB9WC
    Risky unless you have a skid plate.
  • bdymentbdyment Member Posts: 573
    I would only let the dealer change the oil when the vehicle is under warranty. These are good cars and SUVs, but they are some what different in design and engineering. If a warranty claim should happen, it is much easier solved if a registered dealer has performed the work.
    Also I have never been a fan of vacuum extractors for oil removal. Better to drain it.
    I think it's a huge pain and takes a lot of fiddling and a lot of time. I just don't see any real advantage.
  • jfljfl Member Posts: 1,399
    +1 on the Fumoto Drain valve. Had one on my 2000 Legacy and now have one on my 2013 Impreza. Well designed and functional.
  • cmhj2000cmhj2000 Member Posts: 381
    Fumoto valve, love them. Have used them for years.
