2000 Honda Odyssey Transmission
The transmission has just started slipping when it is cold . When it warms up it runs great how do i fix or what could be done
https://www.youtube.com/watch?v=lpIg6w8XpBU
I suppose if you are the manufacturer and you have seen bad things happen as the results of flushing you would recommend against doing this but if you had a Quick Lube or you had bought a machine for your shop then flushing would be a "good thing'?
Of course, those seals needed to be "conditioned" with the additive at the end?
I'm not saying there couldn't be any benefits to flushing but I have mine drained and filled every 30,000 miles and I've never had a problem.
Here is what I do with my customers and my own cars. When servicing a transmission I do a modified flush without a machine. When possible I drop the pan and replace the filter then after refilling I use the engine to pump the old fluid from the convertor through an open cooler line while maintaining the fluid level by adding through the filler until the new fluid shows up in the cooler line. When there isn't a serviceable filter, then I just start with a drain and fill and then do the cooler line trick. That's a good enough routine to replace 85-90% of the fluid, and if the fluid is never allowed to degrade in the first place easily sufficient. Now with my Escape the flushes were performed at 60K, 125k and then at 180K with drain and fills at 30K, 90K,150K. The flush goes through 13-14 quarts of fluid by the time it runs clean. The drain and fill replaces some 5 of the 11 quarts the transmission holds. FWIW, my Escape just turned 190K and the fluid doesn't even change color anymore and looks like I had just put it in when I changed it at 180K. ( I stopped at 12qt since I realized I wasn't going to see any difference anyway).
