Hyundai Sonata in Snow and Ice
Winter driving is a major choice in determining what car I should buy. So I would like to hear about your stories driving the 2006 and newer Sonata's in the snow. And not just 4 inches of snow that fell. I want to hear about bad snow fall and how the car handled with those stock tires. Thanks!
Number one thing you can do to improve the way the car handles in to buy 4 good snow tires. I have a set of directional snow tires on my 2009 and have not had any trouble getting around.
I have found that with Electronic Stability Control and the anti-skid technology found standard on the Sonata, that the car has thus far handled everything thrown at it. I'm able to take corners at faster speed with no loss of control than I can in my wife's older Civic. Got the Sonata after driving a Subaru Forester for 6 years, and it does nearly as well as the Forester.
My Sonata is an '05 and does reasonably well in CT with the all season tires. However, I have one SOB of a hill (steep incline) and 3 sharp curves over .4 miles to get home. When it's bad, I often go an couple miles out of the way (not a joy on bad roads) to avoid this hill. I've seen 4X4's stuck on this hill.
I guess my questinon is, how much do snow tires on the rear wheels help traction? I may have to get new tires before next winter and am curious about snow tires.
I have never met anyone how believes they are a bad driver it is always the other guy.
I came from a 2000 sonata that was a lot better in the snow.
TerryMSU
Grand Rapids, Michigan
BTW, these Kumho Solus tires are not high-enders. I'm sure they were one of the cheapest around, which is why the dealer I bought the car from a year ago put them on. But they've done a great job for me so far.
I have a 2012 Sonata with 24k miles on it. I had the 2 front tires replaced last Sept., and have since found the snow handling pretty poor with all season tires.
In a recent snow storm, I had to stay about 10mpg below most other vehicles to maintain control. Oddly, my car handled more like a RWD, as I had much better torque and traction in reverse.
I'll take to a tire expert to see if the problem is having different tires between the front and back, though I believe the speed rating between the 2 is the same.
Hi guys, I am from a place where the winter temperature goes to -35 degrees cel. Does anyone of you have similar weather conditions? I would like to know if ther is any starting problem in Sonata 2006.
