Visitor Agreement.
STAY AWAY
i'm not a castrol fan myself ..prefer to stay with genuine synthetics.
i wouldn't like the feeling that i paid synthetic price for some refined hydrocracked stuff
http://www.synlube.com/pr02.htm
after I put in AMSOIL 5w30, the engine has started to rev so easily that it is simply amazing, but mind you this started happening after about 3 weeks or so after I changed fluids to AMSOIL. So presumably, it took it's time to clean up the bearings and the engine moving parts of the coating that Castrol Syntec had deposited.
Their syntethic ATF was no better, in fact; useful life span less then Amsoil
Oil, well, very very expensive and you have to add an additive package every once in a while plus send sample to them for review. Further, when I tried to contact their so called testimonial people they never replied to my inquiries.
Plus, most of their data is on old cars, not very scientiifc to me as well.
Thus, I stayed away from trying it, really really expensive.
They all claimed it was very very good.
could all be just hype, still waiting on some others, and what their email says.
Hey wanted to ask ? Amsoil's ATF I thougt was a 3x the manufacturers drain interval no time limit established I called them on this they insisted only 3x the drain interval average car these days is 15,000(toyota corolla) to a ford taurus 30,000 miles, that would make toyotas drain intervals every 45,000 with amsoil and ford 90,000 milses, synlubes claims their ATF is a 10yr 150,000 mile drain. Like there motor oil. Is there a difference between amsoil oil recommendation and synlubes drain interval?
I agree this stuff is very expensive yet if oil changes are almost eliminated and only top off what may be normal consumption and with little wear is the price justified?
Mobil 1 $4.00 a quart average car say 5qts plus a really good filter, round up price about $25.00 per change done every 6months comes out $50.00 a year done over a 5yr period $250.00 barring you have no oil consumption between changes
Synlube $150.00 4qts initial fill 2qts add oil for normal consumption 1 really good filter 2 magnets on filter to catch ferrous metals take out of oil circulation due precursors to oxidation and sludge, just estimating over a 5yr time frame.
No drain and filter changes for that period sounds pretty good. Yet keeping perspective that metal wear is as good as mobil 1 or Amsoils synthetic
Just shooting the breeze again I could be altogther wrong.
Really I appreciate comments because I'm contemplating it's use
Hey armtdm do you have you're oil analyzied every year or so ? what been you're trend analysis like ?
Yet they have some really excellent tech data on lubrication just outstanding, I was perusing the site gave a lot of insight on kinematic viscosity, absolute viscosity, tribology, filter media, quite informative things I had not been apprised of.
I'm guessing it's just another synthetic formula (PAO based, if you're LUCKY!) but they are marketing it in a very different way. That's all.
--- Bror Jace
My brother has a burb the recommend a similar interval I do not trust it, I'll switch it over to Amsoil ATF we've been using it on the 90 honda since 15,000 miles only changed it twice now acculmulated 110,000 miles.
Makes me wander if manufacturers atf is hydrocracked or a true synthetic
My Camry I have Amosil synthetic in since 25,000 (drain and fills every 30,000). I have not replaced filter since 25,000 and now have 138,000. Wonder if filter/screen is getting filthy?
What is the difference between GL-4 and GL-5 API service gear oil? Can I use GL-5 when the owner's manual recommends GL-4? Thanks for your advise in advance.-AW
http://www.manhonda.com/store/sports/index.cfm?Level=13&itemno=AMA-292&CFID=387765&CFTOKEN=48649767
http://www.klotzlube.com
I know some guys restoring old Land Rovers who are using it for that reason alone. They certainly aren't using it looking for that last tenth percentile worth of performance! >;^)
As stated, they have lots of great info on their site and I've ordered through this guy with good results:
http://www.auto-motor-oil.com/
--- Bror Jace
Benefits of synthetic lubricants are one of the hottest topics on our Message Boards. We think that the book "Synthetic Lubricants and High Performance Functional Fluids" does a great job of describing just what can be expected from synthetics - and a whole lot more.
The performance benefits demonstrated by the various tests that have been described are meaningful to the automotive engineer or tribologist, but the average consumer is most interested in how much savings the use of a PAO-based product is going to generate.
This case describes the results of one study that considered both the increased fuel economy and the extended oil drain interval made possible with part- and full-synthetic PAO crankcase oils. The original calculations have been updated to reflect current prices for gasoline and oil in North America. The calculations are based on 15,000 miles of driving and a “do-it-yourself” oil change regimen. A pump price of $1.20/gal for gasoline has been chosen, and the oil has been priced at $1, $2, and $4/qt for the mineral oil, the part-synthetic, and the full-synthetic, respectively. If the oil is changed every 5,000 miles, there is almost no cost differential for the three oils because of the improved fuel economy gained with the synthetics. For the 15,000 mile distance, the savings over the mineral oil formulation is $3 with the part-synthetic oil, and a deficit of $3 is experienced with the full synthetic. If, however, there is only one drain for the full synthetic, the savings goes up to $11. In Europe, where gasoline is much more expensive and the differential in oil prices is less, the savings accrued by the use of synthetic crankcase oils will be much greater.
The use of lighter grades of crankcase oil is one answer to the need for increased fuel economy. The possible downside to this strategy would be a concurrent increase in oil consumption and the loss of sufficient high temperature viscosity for adequate engine protection. Studies show, however, that properly formulated PAO-based synthetic crankcase oils, with wide multigrade SAE performance classifications, can outperform mineral oil based formulations in both fuel and oil consumption, while maintaining superior engine protection.
Click here for more information about the book Synthetic Lubricants and High-Performance Functional Fluids.
In absence of 0W-40, they recommended I go to a 5W-40, which could be found more readily in the US.
Does anyone know the difference between 0W and 5W, in terms of temperature range and viscosity? Does that 0W only come into play in seriously cold environments (the coldest it ever gets here in NYC would be about 0 deg F)?
Also - question about the tri-Synth from Mobil - I've seen a couple of people knock it for lack of Zinc (?). Is this a durability issue (where the oil would have to be drained at shorter intervals) or is it a lubrication/use issue?
-John
I use synthetic, and a self change is
oil : 24.05
filter : 8.50
total : $32.55
i do that about every 12K miles. If i used dino, i'd do it twice as often, say, every 6K miles:
oil 6.50
filter 8.50
total : 15.00 * 2 = 30.00
So, if i self-change i can save $2.55 by using dino oil. That's really not worth the extra work of doing an extra oil change.
Also, if i have someone else do it, the dino is more expensive due to paying labor coss twice. The labor on one change is more than 2.55.
If you figure i get an extra .1 mpg from that saves me $3-4 a year ( i was surprised, but i average 26.1 anyhow ) which covers the synthetic materials right there.
dave
https://dallnd6.dal.mobil.com/GIS/ MobilPDS.nsf/26b7c4b33367a4a086256665004e4266/9337c5cedcf5e32e852567b60056db77?OpenDocument
The defnition of SAE vscosity grades is:
http://www.bobistheoilguy.com/oildefinitions.html
The information concerning the Zinc is bogus (in my opinion) They have a new additive which supposedly enhances wear (alkylated aromatic):
http://mobil1.com/index.jsp
https://dallnd6.dal.mobil.com/GIS/MobilPDS.nsf /26b7c4b33367a4a086256665004e4266/9337c5cedcf5e32e852567b60056db77?OpenDocument
Get rid of the space after.nsf- wouldn't let me paste that long address
hehe - that refresh can be a b1tch sometimes, eh?
The information was useful though.
although it may still be as good (or maybe even better), they do not make that claim to fame anymore due to auto mfr concerns.
my mazda calls for a 75w90 gl4 or gl5. i switched to mobil1 synthetic gear oil which is a gl5. my main reason for the switch was to eliminate notchy shifts during cold winter starts, but i wasnt too impressed with the results.
based on positive reviews, i'm planning to switch to redline mtl-90 next month. hopefully that should take care of the problem.
