... for something better. Right now I'm using Redline synthetic oil ... but if you can find me an oil that pours (at -30F) like Poland Spring water, I just might have to switch! >;^)
$15 for a 5 quart bottle of Mobil 1? That's a steal considering they charge $4.49 per quart. That's as cheap as the SuperTech Full syn. I haven't seen this at our local Wal-Fart. I'll have to ask their automotive guy if he can order this.
... it was me that said that once you get a pour point below -30F it doesn't really matter.
Also, there IS a theory that allowing the engine to spin faster at initial start up (because of synthetic motor oil) in extreme cold is hard on all the other parts that DON'T have synthetic oil in them ... like the power steering, etc ... I remain skeptical about this.
I've seen those Walmart Mobil 1 oil sales before They can vary from store to store even in the same region. Their 'normal' sale price is $17.88 for those 5 quart jugs. I'm almost sorry I switched to Redline synthetic oil ... >;^)
Never apologize for using REDLINE. That's as silly as apologizing for being a US Marine! Without the humor, my point is that you use the best, and it costs more than the pretender to the synthetic throne. Hang in there. The Diamondbacks sure did!!!
... actually apologizing for using the best synthetic oil (Redline) but rather lamenting the fact that I can't take advantage of a really good bargain. >;^)
I mentioned some time ago that at 30 miles on my new Sentra I changed to Mobil 1. Changed at 4000 miles again. At 7K I put on an oversize Pure One Filter and at 10K the oil is a very very light gold- probably lighter than your average engine oil. I really wanted to change, but can't justify it. I will go to at least 8K on this change (Filter at 3K). I guess one of my points is that the 30 mile oil change to syn seems to have agreed with the 'ol Sentra.
don't go longer than the recommended intervals. I know you don't have a Toyota, but if there is a possible issue with something failing on the engine, and you have exceeded the recommended intervals during the guarantee period, you may be denied. It's only a few more dollars to change out at 7,500 until the warranty period is over. The synthetic will still keep the engine in top shape.
I just bought a '96 F-150 truck with a 5-speed manual transmission in it with 124,000 miles on it. I noticed the tranny being a little harder to shift than most (undoubtedly due to the high mileage), especially on cold mornings. Ford recommends a Dextron/Mercon type fluid for this transmission. I bought 4 quarts of Mobil 1 synthetic ATF and changed it. Man it shifts like a brand new transmission!!! I've heard of this happening from Redline, but I can confirm good results with Mobil as well. I really can't understand why all people don't take advantage of the benifits of syn fluids....
I have a 1994 Econoline custom van and owned it for the past 18 months. After turning over 92,000, the AirBag light on the dash started blinking on a regular basis while I'm driving. Recently the horn stopped working too. This van has not been in any kind of an accident. I wanted to know what the possible cause may be. I don't want to have to spend a fortune on this. I have also looked in my owners manual at the fusebox diagram. There, I do not see the Horn listed. However, I do see Horn listed in the Power Distribution diagram on another page. Can someone explain that to me? Thanks so much Could a fuse be causing the AirBag light to blink?
Sooner or later the above post is going to have to see a mechanic to get the codes read so rather then toy around looking for a quick and dirty solution to a problem only a tech could solve spend the buck for the diagnostic, you don't have to get it fixed.
there are some things that just cannot be fixed from a message board.
I have a new 2002 Explorer with just under 700 miles on it. I plan on going to Red Line Synthetic engine oil (based on what I've read on this message board and subsequent reading)and a Pure One filter after about 2,000 miles. My question for anyone who can help is, do I need to do anything special on the first synthetic fill? Do I need to flush the old oil? Do I need to run a short interval the first time? How about if I want to switch to syn on the tranny, differential, etc? Thanks in advance.
Redline recommends not going with their syn until 10K on engine, I believe. Have no idea why. That was not even necessary for old engines (according to Mobil) I switched to Mobil 1 at 30 miles.
Chevron makes a 5w-20 now its not a sythentic but the numbers on the data sheets are close to a synthetic stock. www.chevron.com to look it up. once on the main page goto Fuels/OILS next page goto Motor Oils next page goto Product Data Sheets then look for sheets that start with (S) for supreme moter oils. Now their are two pages of data sheets so go to next page at the bottom. Sorry this seems tidius but this is for the new commers. I looked at the motor oil skit that people have been posting Whats The Best Oil To Use. And notice that if you check out the manufactures sites you will notice that not all the oils meet the new 2001 SL/ GF-3 specifictions For example Penzoil Synthetic is only SJ/and GF-2 this is not the only one. It seems to me the synthetic oils are behind these new specs. I ues chevron supreme synthetic 5w-30 in my two cars. Just for your info. Thanks Tony
Nothing special is needed but ther eis no hurry. I jsut converted a new Buick to synthetic (Amsoil) at 4,400 miles, had the oil analyzed, normal except for high silicon which will be seen until about 20,000 as gaskets and seals wear in. So 2000 is fine but so would 3000 or 5000 as well.
You didn' t say how often you plan on changing oil and filter/ On two of my cars I go 7,500 oil and filter, other 2 go 12,000 filter at 6months/6000 miles
I use Redline gear oil but Amsoil oil and filters for all else, slightly less expensive then RedLine.
Red Line says run conventional oil for at least 1,500 to 2,000 miles so I'll go at least until then. I'll probably change once with petrobased because my oil already looks kinda dark, not nice and amber like new oil. (Could there be additives in the original oil? The few things I’ve read says no.) I planned on sticking to Ford’s recommendations on mileage (5,000), though, to assure no warranty issues. I know it’s overkill, but doing the oil change myself saves a lot of money anyway.
ocelot1 made a point regarding certifications which got me thinking about whether Red Line met Ford’s WSS-M2C153-G certification for my 4.0L V-6(again, worried about warranty issues). Their tech sheets don’t even reference SL or GF-3 certification so I emailed them to ask. I’ll let you know what I learn.
I’d like to use Red Line products in the trans, diff and rear end, too, but I’ll have to find a shop that will do a credible job changing it for me since I don’t have the equipment to do those myself. What’s your recommendation on changing the transmission fluid to synthetic? Just drain it and refill with syn or something more extensive to get more of the petroleum-based stuff out?
Greg, I believe that Redline says to go with conventional oils for 3,000 miles before switching to their oil. But Mobil 1 is used in the crankcase at the factory for some premium automobiles. These two oils, however, are vastly different formulas.
Youi can e-mail Redline regarding your concerns but I'm 99% sure that there latest formulas will meet or (likely) exceed SL specs. Also, give them that Ford number. The problem may be that Ford's specs might be proprietary and they don't release them. Only one way to find out.
Ocelot, I wouldn't be surprised if the Chevron 5W20 is formulated with "IsoSyn" whish is hydro-isomeruized petroleum ... which some companies WOULD call synthetic. They use this stuff in their excellent "Delo" line and have a small symbol of it on the front.
Do you know if their synthetic is PAO or hydrocracked crude?
Except for the Delo heavy-duty oils, they are not sold in most parts of the northeast.
You're probably right about the certifications, but being the paranoid type I have emailed Red Line and included the Ford spec number. I’ll let you know.
Ford would have to publish the specs otherwise no one would ever be able to meet them. Shell states that they meet the Ford WSS-M2C153H on their 5W-20 FormulaShell so the spec is out there for producers to use.
As for the mileage before switching, one of Red Line’s tech support guys said, “We recommend that you allow the rings to seat before installing the Red Line, this will typically happen easily by 1000 miles, if you wait 1500 to 2000 miles, then most of the high initial wear will have occurred.” Sounds like there’s some wiggle room – just let the rings seat and then go for it!
Wait until you have about 15,000 miles to switch to synthetic transmission fluid and then do a complete fluid change. After that you can do drain and refills if you want or stick to the compete fluid change mode, which is a lot more expensive, of course.
any of you guys look into this product? the race car guys swear by it, and i have one friend in Hawaii who uses it and everything checks out great. and yes, it looks like koolaid when you pour it.
Although mailsail2 says to do a flush or complete exchange at 15,000 I would say don't waste your money. If you pan has a drain plug this is a simple do it yourself and a drain and fill gets about 50% of the fluid so if you change at 15,000 then every 30,000 you will be in great shape. This has worked for me on multiple cars. Even with a drain and fill with synthetics every 30,000 this is an overkill.
Quite honestly, if you are going to be worried about the warranty and change with RedLine every 5000 I would not bother. I would go with dino at 3000 until your warranty is up and then switch. RedLine is too expensive to change every 5000 miles and with dino at 3000 you will get the same longevity out of the engine. Only reason to use synthetic given your situation would be very cold climate.
I am convinced that part of the reason manufactureres are going towards powertrain warranties of 100,000 are to assure people concerned about voiding theri warranty to keep going back to the dealer for service. Most people drop dealers for oil changes as soon as the warranty is up, extending it now builds service dept. revenue.
Pepper, Yes, I thought it was ambiguous. Since there is no legal definition of "synthetic" oil and Chevron boasts about their hydrocracking and isomerization technologies, I'd be skeptical of their synthetics being PAO.
Seelig, take a look at Royal Purple's site:
www.synerlec.com
Their "tech information" is laughable and their formulas are not even 100% synthetic. I'd avoid this over-hyped stuff. They are just another small company trying to take advantage of people wanting a better oil for their cars.
I agree, if you need to change your oil every 3-5K to maintain your car's warranty, there's not much point in synthetic. A regular oil is perfectly fine if you change it every 3,000. I used mobil 1 on my saturn every 3K but i realize now that it was a big waste of money.
I have seen people promote royal purple very heavily. It's a dino oil with a very heavy duty additive package. I still beleive that the synthetic base stock is an important thing.
I'm pretty sure that synthetics, even though they don't list an SL standard yet would more than exceed the new SL standard.
I spoke with Quaker State about their New 5W-20 SL. It is definitely a Synthetic Blend oil. They had to add the synthetic because conventional oil that thin wouldn't meet the wear requirements.
And why is the oil so thin? That is, why is 5W-20 being specified? It must be to meet CAFE standards. I would not easily assume that the tolerances of the engines so designated are so tight that oil above 20weight will not squeeze into the clearances.
Yes it is a pao based synthetic I called their tech line about 6 months ago and asked. Threre base stock they developed and they refine it too,for them selves and other pao based synthetic oil's that are on the market. I think mobil is the only other company that refines what they use all the others just buy a base stock and add their own additive package.I have to order my oil from the local chevron/union76 retailer they run about 10 cardlock fueling sites in are area and deliver fuel oil for furnaces. I pay 3.64 a quart for the delo400 0w-30 syn, 3.56 a quart for the 5w-30 supreme syn. last time I bought the delo I had to buy a 5gallon container Whoooo!!!! man thats a lot of oil they sell it in the Q,s but the guy had these as a miss order and made me a deal. Tony
Well, the waste was paying for synthetic.. Saturn said going over 3K miles per change would void the warranty, synthetic or not. They even made be use 5w30. In the bmw i have now, i use 15w50.
My mechanic saw a film by Ford that showed sludging around the valves when a 10W-30 was used. Interestingly enough they never mentioned a 5W-30. Nor did they mention synthetic.
I saw the stuff being poured once. It really does pour like water.
There's no question to me that the CAFE standards and trying to reduce Miles per Gallon is a huge reason for the lighter oil. I believe Honda does the same thing.
Personally I would use 5W-20 during the warranty period then switch to 5W-30 after that.
Yes, 3,000 was the max interval, and no extra was allowed for using synthetic oil or filter. In that situation the money i spent on synthetic was wasted, as regular oil can go 3,000 perfectly well. I later used synthetic for 10,000 intervals in the saturn after the warranty was up. That was probably too much, as the oil got pretty gritty--the engine was 'loose'. It also ate a quart every 1,200 miles or so. I had a long commute, so i ended up dumping in 1/2 quarts of mobil 1 in every week.
Mobil 1 in my bmw seems perfectly fine after 10K miles. It's still the same color. I use the oil change lights on this car, which seems to want me to change it every 11,000-12,000 miles with my regular driving, longer if i throw in several road trips. I think it wants a change every 480 gallons of gas used. 3K changes with dino would be more expensive by a significant margin. The car takes 6.5 quarts of oil and a $7 filter. $35 in materials over 12K miles, vs $12.50 every 3K miles. And this even excludes labor--that makes it $60 every 12K vs $35 every 3K.
Our saab puts more junk into the oil, it seems.. It turns pretty dark after 4K miles or so. We stick to the manufacturer's guideline of 5K mile changes there, but we use mobil 1. Saab claims you can use dino oil for 10K intervals. I really doubt it. I think using synthetic is more crucial in the saab because the oil cools the turbo, which gets very very hot, and it can coke regular oil if you don't idle the car for a minute when stopping after driving hard.
A friend of mine has an old subaru. The oil turns black in a few hundred miles after an oil change. She uses dino oil and changes every 1,000 miles.
So, i guess what i have learned is it matters on the car and the conditions--warranty, driving conditions, the mechanical condition of the car, etc.
The saturn would have been better off with 3,000 dino changes. It used up the expensive oil, and dumped a lot of contaminant into the crankcase, it seems. The saab & bmw are best off with synthetic for their own reasons ( long intervals, hot running ). Synthetic in the old subaru would be a waste.
Ocelot, it's good to hear that Chevron's synthetic oils are REAL synthetic oils and not some processed-petroleum-pretender stuff like some others *cough, Castrol Syntec, cough*. Their site is very informative and from what I've seen of their oils (in terms of composition, etc ... it seems to me that their quality is solid. I think I remember hearing that THEIR synthetic oils were PAO, but Amoco, who they purchased a short while ago was hydrocracked crude. Same thing as far as Havoline who they JUST aquired (hence the TV ads). There's something about buying oil from an actual REFINER rather than a bunch of marketing bozos that merely re-package someone else's product. I wonder if Ashland (Valvoline's parent) makes their own PAO for Valvoline Synpower or whether they get it from Mobil or Chevron?
When I buy heavy duty dino oil, I buy Chevron Delo 400 in 15W40. The only other weight available around here is 30W. For older power equipment we have around here, the machines that keep mosquitoes away when they're running (if you know what I mean), I use this stuff ... sometimes with a little Mobil 1 15W50 mixed in.
wtd444, yes, 5W20 is strictly to pick up another teensy bit of mileage ... about 0.5-2% more which allows some companies to keep selling some gas-guzzlers without being hit with extra taxes. I've talked to people about this when it was brand new and they assured me there was no way that all the vehicles in both fleet's engine tolerance could have changed in one model year. If you think about it, that makes a whole lot of sense. If I were to buy a new Honda or Ford that calls for this ultra-thin stuff, I'd use it for about 15,000-20,000 miles (draining it every 3,000) then switch to a synthetic 5W30 for the next 60-80,000 miles. This is essentially what Mr. Detailer said.
Interesting to hear about the Ford's aversion to 10W30. How long ago was this? I knew a mechanic that was told not to use 10W30 in his Chevy Lumina's V-6 (3.1L, I think)because it caused the rings to stick and scored the heck out of the front bank of cylinders. I don't know if he was full of it or not.
dhanley that's odd that Saturn would make that kind of threat. I have a buddy that has 90,000 miles on his '97 Saturn and it all of a sudden started burning oil at the alarming rate of 1 quart of 5W30 every 1,000 miles. I know he changed his oil (dino) and filter regularly. I wonder what happened? My guess is his valve seals disintegrated as there are no other signs of engine trouble (leaks, fouled plugs, oily exhaust film, etc ...). I told him to switch to 10W30 for most of the year (possibly Valvoline Max-Life) and keep me posted.
What does your BMW call for? 15W50 is really thicker than necessary in most parts of North America ... even in the summer. 10W30 is a good, heavy-duty choice and you won't lose a little bit of mileage and horsepower (2-5%) like you will with the thicker stuff.
I love the bit about your Saab Turbo calling for extended oil changes using dead dino oil. Are these people crazy? 10K miles with the heat that can be found in a turbo's bearings? That's just foolish. I guess they are just interested in getting the owner through the warranty period.
I deal a lot with kids ("ricers") from Southern California and they buy into all kinds of silly hype and one of my pet peeves is some of their allegiance to Royal Purple oil. This stuff is really all flash and hype. Out of the bottle, I heard it has a deep purple color to it ... but this is just a flashy gimmick because one of the people I talked to about this stuff says that the color goes away quickly. Now, why would you add a dye to your fluid that will quickly break down? Automotive oils don't need highly unstable additives ... unless you are more into shallow marketing than you are into producing quality lubricants.
I find it odd that a multi weight oil like 10w-30 would cause any engine damage 30w is 30w no matter how you look at it? all oil if formulated right ends up 30w scoring pistons and sticking rings seems to boggel my little mind? I might be able to strech to say flow might be a factor/light duty oil pumps? I need some help here if any is available.
Yes, on the saturn, it's the valve seals according to some people i talked to. Apparently they have a wear problem with those. My cousin ( a mechanic ) told me to switch to 10w40, but it didn't help much. My consumption of 1 quart evey 1,200K started rather suddenly at 60K miles, despite mobil 1 every 3K. So, definitely a waste there.
The BMW calls for 5w30 up to only 50F. They recommend 15w40 if you experience temperatures over 50F. The mobil 15w50 as as thick as their 15w40 so i figure it's OK. They say the 15w40 is ok down to -20, and again the mobil 1 should be as good according to the charts i've seen. They just use thick oil -- I guess the oil pump is pretty powerful?
Yeah, i won't use dead dino on the saab at all. But for 10K miles? With it cooling the turbo? Yikes!
I think you're dead on about the royal purple. Why add dye to the oil? I could buy regular oil and add a little dye to it, but i'd rather not!
brorjace- considering that you are probably the most knowledgable oil enthusiast here, would you please expand on your opinion about royal purple just being nothing more than "hype?" i ask this because you must have some first hand info that proves that RP is what you claim it is. since you are so willing to suggest the Valvoline Max-Life to someone, i feel you are in posession of long term test results on whatever you approve or disapprove of when telling us what we should or shouldn't use. thx ---seelig
Bror Jace – You were at right about Ford keeping their oil spec confidential, they won’t let me in on their little secret. I have to share their reply to my question from “Customer Care”. It was so full of crap; I almost didn’t know how to respond. Sorry for the length of this, but I have to show it to you. It’s a cut-and-paste - I changed nothing.
They wrote: Thank you for your message of 11/12/01 regarding your 2002 Ford Explorer. We appreciate the time you have taken to write us regarding a list of commercially available engine oil.
Congratulations on the purchase of the 2002 Ford Explorer! We are pleased to welcome you to the Ford family.
All alterations or modifications to Ford Motor Company vehicles must be done in compliance with all applicable State and Federal statutes and regulations. If an after-market modification is linked to a component failure, the warranty may be voided for that repair. If this were the case, you would need to seek assistance from the manufacturer or installer of the non-Ford Motor Company product for repairs. Therefore, Ford Motor Company does not recommend modifications to your vehicle.
We strongly recommend discussing this modification with the Service Department of your local Ford dealership before initiating this procedure. Ford Technicians have the necessary training and experience to advise you of what effects this modification may have on your warranty or the operation of your vehicle.
Ford's goal is to make your ownership experience an enjoyable one. Customer satisfaction is our number one goal.
At Ford Motor Company, we consider the satisfaction of our customers as one of our most important objectives. If you have any other inquiries or concerns, please feel free to contact us and we will be happy to address them.
Thank you for contacting Ford Motor Company. (End)
Incredible! I asked why they would tell me (in the Owners Manual) the spec on all other fluids in the car, but not the engine oil. No reply that makes sense. I guess they think their dealers are the only ones that can change oil responsibly. Either that or it’s too big a moneymaker!
Red Line confirmed that their oil satisfies Ford’s requirements.
dhanley, Thanks for the info. I'll forward this on to my buddy who's lamenting the way his Saturn is sucking down the petroleum syrup. If it is in fact valve seals, that is fixable without tearing the whole motor apart ... unlike ring and cylinder work which is often so involved that you might as well go for the complete rebuild. I know that the Ford 4.6L V-8 has a similar problem. Everything is fine and then all of a sudden, it goes through oil like mad and switching to a heavier oil barely makes a difference ... until you try to turn the engine over on a really cold morning.
I heard it's the material the valve seals (located at/near the valve stems - relatively easy to get to) that crumbles over time. Replacing these should return the car to its previous oil consumption pattern. We don't have emissions testing in this area of upstate NY but I can imagine how consuming a quart of oil per month would affect them.
As for the Mobil 1 being a waste, don't be too sure. Your bearings and all the other parts on the car must have been really well protected over all those miles ... even if that stuff couldn't save the valve seals.
Do you have a URL for a good on-line Saturn group or two? I'd like to pass that on as well.
I'm surprised your BMW calls for 15W40 ... but I guess that makes sense if they want to use extended drain intervals and dead-dino juice. Those temperatures ARE Fahrenheit and not Celsius, right? >;^)
Then your choice of Mobil 1 15W50 is a really good one and I'd stick with it. It'll flow better than the dino 15W40s in the cold (although I'd be running 5W30 or 10W30 around here during the 4 winter months) and will protect better, longer when the temps rise.
As for what Saab is smoking, I think the DEA should look into it. >;^)
greg, Sorry to hear that Ford's response was merely a bunch of corporate CYA effluvia. That's typical these days. It's funny, but I never considered using a well-known brand of engine oil as "an aftermarket modification to my vehicle". That reply makes little sense. It sounds like you asked them what happens if you mounted a turbocharger on your engine. What a bunch of jerks.
Honda gets that way too sometimes but at least with them, I KNOW that many of their fluids are a unique formulation (especially their power steering fluid) so there's a reason for their warnings, some of them anyway.
Seelig, Don't like what I write, eh? Well, I don't consider myself the most knowledgeable person here but others that know more than me have been keeping quiet lately or have moved on altogether. Still, I think I have a lot of good advice to offer others that haven't spent over a decade looking and trying different lubricants.
In the case of Valvoline Max-Life, I was quick to dismiss this stuff when I first heard of it and saw the price. I figured it was regular motor oil with a bit of a seal-swelling additive and not a good value. A guy I know called their 800 number and talked to one of the chemists. He said that the oil was actually Group III stocks (instead of typical Group II) so it is chemically very similar to Castrol Syntec ... at half the price. Also, this stuff, along with the additive package was very beneficial to seals (test info on Valvoline's site). So, I recommended it to a buddy that owns my old '90 Integra (160K miles on the clock) because he was thinking of switching the car off synthetics as it was getting old, rusting and leaking a bit more than usual. When he switched oils, he told me that he was impressed with the stuff and it cut down on the car's oil consumption (burning and leaking) significantly. His testimony was good enough for me to make occasional recommendations to others.
As for Royal Purple, it is not even a fully synthetic oil ... it's a blend of some synthetic (PAO? hydrocracked crude?) and a regular/mineral oil. You have to really dig around to find this out. The fact that they're sly about this important tidbit is a clue that something's not on the up and up. Just how much of their formula is synthetic and how much is much cheaper dead-dino juice? Who knows? Last time I checked, they weren't saying.
Another clue that might steer people away from their oil is the laughable "technical info" on their site. See for yourself:
www.synerlec.com
Their data shows some numbers but they don't tell you what they're measuring, if anything. Is it some sort of 'specialness' quotient that Royal Purple has above and beyond all other oils? To me it's all so much nonsense which makes them look very unprofessional and not entirely honest. Where are the industry standard SAE tests that some other synthetic producers conduct and make public, hmmm?
Royal Purple has a secret ingredient called "Synerlec" in their oils. If this isn't the classic snake oil sales pitch, I don't know what is. Their secret ingredient is probably common ZDDP or PTFE or some other compound found in the 'miracle' products whose companies are all currently being sued by the FTC for false advertising claims. This sort of thing really turns me off.
Ever see the Royal Purple TV ads on ESPN, TNN or the like? They are produced JUST LIKE those snake oil infomercials. When I see this, I don't want to walk away ... I want to RUN. >8^O
I've never used Royal Purple (it's sold mostly in the West and Southwest) but one guy I talked to that tried it said that the purple color goes away after only a few hundred miles. Assuming this is true, ever wonder what happens to the dye used to turn the oil purple? Does it evaporate off through your PCV system or does it decompose and form sludge and goo inside your motor? So, what's the point of adding that stuff anyway if it's so unstable? I'll tell you why it's there. It's merely a gimmick to give the average consumer the false notion that Royal Purple is 'special' and different from other synthetic oils on the market. I can just hear the typical motorist as they pour this stuff into their engine:
"Ooh, look at the purty color! This stuff must be MUCH better than that ugly junk I used to use!"
Aside from the people on their ads and website, do you see any REAL racers that use Royal Purple? I don't. Compare that to the example I often cite of the Goodyear advertisement in Grassroots Motorsports that showed pictures all the SCCA championship teams who used their tires. A close inspection also revealed that 8 out of 10 of the cars pictured also used Redline oil. Now THAT is a powerful (because it was unintentional) endorsement.
I heard from one Subaru owner who put Royal Purple gear oil in his transaxle and it became noticeably noisier than when it held the factory fluid ... a sure sign of increased friction and/or wear. Afterwards, he switched to Redline or some other brand and was much happier.
All the evidence suggests that Royal Purple is not one of the better product lines available ... and it's premium-priced to boot. Yes, my evidence is mostly anecdotal and you might nitpick at some of it here and there but when you add it all up, it becomes overwhelming and suggests that this stuff, like some others (synergen, nuology (sp?), etc ...), is best avoided. This is especially true when you look at how many reputable brands are available. The larger companies have teams of chemists working full time on their formulas. Contrast this with a couple of guys working out of their garage who bottle up some stuff they bought wholesale from some other company, put an unstable purple dye in it and that's supposed to be an improvement? Sorry, but I can't believe that. Not for a second.
is it just me, or do you come off sounding like a horse's a#* in most of your posts?
brorjace says what he thinks and does his best to explain why he thinks so. He doesn't pretend to be the Grand Poobah of engine lubricants. Cut him some slack. His posts are some of the most thoughtful, informative, and helpful ones on this board. I enjoy reading them. And I enjoy reading the posts from you that discuss the topic and not the other posters.
I think www.saturnfans.com is a pretty good site for your friend.
The valve seals may be easy, but the way i figured it, if i had kept the car 100,000 more miles than i did, running dino, dumping in a quart every 1000 miles.. It'd be <$100. That would cover almost no work at all.
I sold it just before 100,000 miles, so it cost me 50 quarts or so, it just irked me that those were mobil 1 quarts.
I'm sure it did a good job protecting the bearings, but as i sold it before 100,000 miles, it probably didn't help me too much.
I agree about the royal purple. I have a nasty gut reaction to snake oil. Unfortunately there seems to be a lot of it in car care.
Received the monthly Newsletter/Marketing Pitch from Amsoil yesterday. All of their oils are now SL rated.
Had a conversation with a new Porsche owner (Boxter S) a few days ago, recommended change interval is 12,000 miles and they use the European weight 0W40. He said it looked like water. Another owner had a 10 year old 944 that he changes the oil on every 10-12,000 as well.
Does anyone care to comment on why European high performance engines can have the 10-15,000 recommended intervals yet the four bangers and six cylinder American and Japanese engines still recommend the 3,000-7,500 changes. Granted the performance engines have a higher crankcase capacity by several quarts but is that it alone?
than us. They may not have as many quick-lube places beating the drums of fear and stampeeding the masses into the 3K oil change. It would be interesting to get the perspective of a European in this area.
--- Bror Jace
So, as someone mentioned, who cares beyond minus 30 F, The rest of the car is frozen solid but the oil will pour?
--- Bror Jace
--- Bror Jace
Why don't you try to find a Ford or electronic gremlins related topic in this forum (there are nmany to choose from) and post your question in there?
--- Bror Jace
Thanks for your help.
--- Bror Jace
Thanks much!
www.synerlec.com
--- Bror Jace
dave
dave
Well, the waste was paying for synthetic what are you saying here?????
dave
--- Bror Jace
dave
thx
---seelig
--- Bror Jace
www.synerlec.com
--- Bror Jace
dave
