Do you currently own a 2019 or newer RAM pickup? A reporter would like to speak with you. Please reach out to [email protected] by 1/27 for more info.
Instrument Panel Freaking Out
HELP! My freaky instrument panel is driving me crazy. It started with the radio losing power and coming right back on. Then the gauges started losing power and coming right back on. Also the I/P lighting and temp. control display are now doing it. One at a time or all at the same time. When I turn off the car it will sometimes begin clicking loudly from under the dash near the steering column (not the faint turn signal relay sound), always rhythmically though sometimes very fast and sometimes the same slow speed as the turn signal relay. When it does this clicking thing it can sometimes take 3 or 4 turns of the ignition switch to start.
The loss of power problems seem to happen as I begin to apply the brakes and has happened when putting up two windows simultaneously, though it happens mostly when just driving along. The heater/AC blower motor will also slow down sometimes when I first apply the brakes.
Obviously an electrical issue, probably a bad ground, but does anyone know what else might cause this? The turn signal switch module needed replacing so I did that hoping that the problem was in there. Didn't help. Disconnected the remote start even though it was installed a year before these problems started. No difference. Searched forums and see there's apparently a major ground connection under the front passenger floor carpet which I haven't yet tried, just saw that. I did clean battery connections.
I sure would appreciate any help. It makes for interesting (ghostly?) drives but it is really starting to get to me.
Thank-you all for any suggestions!
If ANYBODY can figure this out it would be a miracle. I just hope it's soon before the car (or I) completely lose it.
That's what I would do before tearing into any wiring harness or paying a specialist to track this down.
Thanks again
Thanks again and again
