Isuzu Rodeo Brake Problems
Anyone else have this happen? You put your foot on the brakes and nothing happens. Next thing you hit the car in front of you and are standing before a jusge trying to explain your brakes failed?? Luckily I had enough evidence on the 1998 Rodeos brake problem that was suppose to have been fixed but obviously wasn't. Still had to pay court costs but beat the ticket. Be VERY careful out there!! These brakes are bad. Should have learned with my first totaled 98 Rodeo when the dear asked no questions just gave me another one that was all souped up!! Has this happened to anyone here? Please make sure your brakes don't just stop working like mine did! Oh they do reset themselves, big deal after a crash!
I have no access to a way to bench bleed the master cylinder. However I was told it was possible to install it without this step but it would take me much longer to bleed the system.
I started bleeding with a helper to pump and hold the brakes at the master cylinder where I connected the new lines, then moved on to the passenger side rear wheel, then at the drivers side rear wheel, then the passenger side front wheel, ending with the drivers side front wheel. I bled each wheel individually until I got nice clear new fluid comming out with no air I could detect.
I do have good brakes after 3 steady pumps, but the pressure bleeds off quickly after a few seconds until you give it the 3 pumps again. I have since repeated the bleeding process multiple times until I have gone through 4 quarts of Dot 3, and still no improvement.
The Haynes manual I have states something about bleeding something called "a modulator" first because it is possible for air to become trapped in it. However the book does not state where this "modulator" is or what it looks like, and I've had no luck in finding it. The vehicle does have ABS.
By the results I'm getting I can tell there's still air trapped in the system somewhere. Has anyone else out there ran across a problem like this? If anyone can help me solve this issue it will be much appreciated. This is the only vehicle I have and I must depend on it.
I thank you for reading, and any help you can give in advance.
Phoenix
hope that sounds clear.
has any body had an issue similar to this.
cheers
buddywrecker
I'm also having problems with the brakes on my wife's 1998 rodeo!
She says from time to time the pedal starts jumping when she tries to stop and there's no brakes nothing she has to use the emergency brake.I'm thinking it's the brake booster iv replaced all calipers wheel cylinders pads drum pads Air Blade or gravity blade iv done both.there's no break light I need some help please
