Erratic temp reading -1997 Dodge Ram 1500
I have a 1997 dodge 1500 5.2. It started out dying when warmed up. I hooked it up to the scanner and the temp readings are erratic. Engine dies when it is at -20 thru -40, but scanner does not read at that. Changed the computer, and other parts mentioned on forum but still dying with erratic readings. Any ideas???
When the sensor is reporting a cold temperature you would measure a high voltage, when it is warm it would be a low voltage. The circuit uses a 5v reference signal that comes from the computer, passes through a resistor inside the computer and then goes out to the sensor. From there it goes through the sensor which will have a varying resistance depending on the temperature and then goes to ground back at the computer.
When you see -40 in scan data that means the circuit went open. When the circuit is open you will see 5v right up to the point that the circuit failed and then 0v after that. The ground side of the circuit (return) should be close to 0v when the circuit is operating normally. If that rises to 5v when the scan data is showing the signal to be erratic then it is the ground circuit that is failing. Any Ideas?
Sure. Test, don't guess, each and every time no matter how obvious or simple a problem appears to be. I've seen countless repair attempts and advice given that try to suggest knowing how to diagnose and fix a car equals knowing what part to replace based on nothing other than what a given symptom is.
To test a circuit correctly you have to know how it works as well as how it could possibly fail. I've given that to you above, now you have to perform the tests that prove exactly what is happening and by doing that you will solve that problem.
